Looking for ICs for convergence on Toshiba 13J chassis part no sta 4501m
    Scholar:
  • 135 Answers
Sir convergence ic for 5401 are available here
http://www.electrospec.com/electronic/components-parts/index43.html
just type 4501m in search bar..
thank u
Posted on Jul 08, 2008
  • 4,234 Answers
This part can be found at tritronicsinc.com for $112.01 using the Toshiba part number: 670097501
Dan
    Genius:
  • 1,847 Answers
You can for the part in this site ...
http://www.electronic-repair-kits.com/RepairKits.htm
    Guru:
  • 1,894 Answers
Please have a check at the part number again.
My TV is the Hitachi model 51UWX20B and tried using magic focus to line up red color. Picture looks like 3D with red off center. When using magic focus it gets to the red phase and it shows the number 5...
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
Jul 04, 2011 | Hitachi 51UWX20B 51" Rear Projection...
My Toshiba 53H71 rear projection TV's picture looks like double vision with a heavy tint outline how can I fix this???
Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs.
Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person.
Hope these info will help.
Thanks.
Jun 11, 2011 | Toshiba 53H71 53 in. Rear Projection...
I purchased the convergence chips for Samsung PCL5415RX/XAA TV. Do I need to remove the entire sub deflection board to R&R them?
Yes, however I would be surprised if changing the two Ics will repair the set, as that chassis should always have the sub-deflection board replaced since most of the resistors will be stressed. Thats why samsung changed the later chassis's by removing the convergence circuits from the deflection board as its almost 98% certain that the deflection board will need replacement when the ICs fail with those chassis designs unless every component in the convergence circuit is replaced which will cost more than the deflection boards do. But you may get lucky but if the ICs dont cure the problem you will need a new deflection board
Dec 23, 2009 | Televison & Video
TN50X81 - one convergence IC runs hot...TV powers off after 5min
What was the STKs that was in set ? If 110s always upgrade to STK392-180s. If they were 392-560s go back with the same. they worked differently then the 110s 150s 180s
Nov 27, 2008 | Toshiba TN50X81 50" Rear Projection...
42H83 Convergence
Yes the convergence ICs need to be replaced, however so dont the six 1.8 ohm 1watt resistors as Toshiba recomends replacing those six resistors when the ICs are changed. You can get the 50H71 / 50H82 Convergence repair kit as the 42H83 is identical to the 50H71 series, so the kit will work for your model. Heres the link where you can get the kit.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | Toshiba 42H83 42" Rear Projection...
Convergence
Dan
Jul 08, 2008 | Televison & Video
Looks like watching 3D movie(colors) and rounded
This is a convergence problem and is either bad connections on the convergence ICs or defective ICs. If you feel that you can solder, you should be able to repair this yourself. First try resoldering the pins on the convergence ICs. If that fails, replace the ICs. These ICs are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
May 13, 2008 | Toshiba 57HDX82 57" Rear Projection HDTV
Looking for convergence part number
yes they are the same Convergence ICs number STK392-110 you need to replace both ICs. You can get replacement ICs at the following link and they provide free instalation instructions with pics so you can do the job yourself. Heres the link.
May 12, 2008 | Hitachi 43UWX10B 43" Rear Projection...
43UWX10B problem with green
if you have a 2 IC convergence chassis they dont control the green , However if you have the 3 IC chassis the green is controlleed by the third IC these are usually STK4275 or simallar single amp ICs. Which type chassis does your hitachi have? Its possibly related to the digital convergence board if all resistor near the ICs are good. Do you have the service manual? I can post a link where you can get the full service manual if you need one
Mar 29, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
