Question about HP Office Equipment & Supplies
Have just bought new printer cartridges but printer will not print it scans and copies but does't print
  • 44 Answers
Ensure that you remoove sticker before incert catridge
Posted on Jul 08, 2008
    Sergeant:
  • 233 Answers
Chick the driver and the lpt or usb cable ports
4 Suggested Answers
  • 96 Answers
SOURCE: printer does not make black
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Posted on Aug 26, 2008
SOURCE: Print Cartridges Refer to documentation (No function works)
I was getting this same VERY unhelpful error and the only thing that solved it for me was to buy another genuine HP black cartridge (350XL). As soon as I put it in, it cleared the error and sprang to life. As a matter of interest, before this happened, the HP Toolbox utility was also saying that the old cartridge was nearly empty. So why on earth doesn't the printer tell you the same thing??? Come on HP - get your firmware sorted. Disappointed.
Posted on Nov 26, 2009
  • 64 Answers
SOURCE: Faint copies, despite new cartridge.
Go to Additional Functions> Common Settings> Toner Saver Mode and make sure its off.
Posted on Dec 30, 2009
Black lines are appearing when i print and copy from my kyocera 1130
Your print head or some of the mechanism has something stuck in it causing the line. I would start by cleaning the print head if possible, if not you will probably have to replace the print head, but I would clean it good before I bought a new head.
Col.Dana Gillespie
Nov 29, 2014 | Kyocera Fs-1130Mfp A4 Mono Multifunction...
Why won't my HP Photosmart 5510 copy?
first you confirm scanning is working or not if it is working fine there is no issue with printer, if it is not working problem found with scanner assay you need to contact hp service center....
May 04, 2014 | HP Photosmart 5510 Wireless e-All-in-One...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Scanning and copying.
Check out this link to get the problem solved.....
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu03024&cc=us&lc=en&dlc=en&product=57769
Nov 25, 2009 | HP PSC 750 All-In-One InkJet Printer
My F4280 HP all in one wont recognize the refilled cartridge.
hello, attempt to clean the sensors on the bottom of the cartridge with some kind of solvent and q-tip. If the ink cartridge has sat awhile before you refilling it then the jets will be clogged dry and you will need to purchase a new one for your printer.
Oct 02, 2009 | Office Equipment & Supplies
How come Alignment of Cartridge needs at each printing?
I just go ahead to print and do with what the printer wants me to do. Because I just bought 2 black cartridges, when I use them up, I will buy another printer, different brand, I regretted that I bought Lexmark printer, the ink tube is so little and very expensive. I wish I still had the previous printer . It was still good and new, it has bigger ink tube (1 1/2 times) but the only reason I turned it down, because it was only for printing & copy, it does not have scan or fax which I very seldon use those. Thank you anyway.
Feb 05, 2009 | Lexmark X8350 All-In-One InkJet Printer
Lexmark (Invalid cartridges)
That printer uses Lexmark 32,33,34,35 cartridges. The branded cartridges should work. Have you contacted Lexmark's technical support center? Contact information is on www.lexmark.com. They should be able to get you going again.
Mar 09, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Hp 7310
If the color cartridge doesn't print the color bars on the alignment page (either, redish pink, yellow or blue) then the alignment process will not finish. Same for the black. If the black cartridge is printing ok, then replace the color cartridge and try this again...
Jan 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge problems
Clean the heads, printer is not reading new cartridge or refilled cartridge. You may also have a paper jam if alignment is affected. Check for little jams, post back if no go lilacgerry xxx
Dec 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
Ben Johnson
