Question about Acer AX1200-U1520A PC Desktop
The local municipal power supply cut on and off intermittently and several times browned out over the last week. the PC could only be restarted after unplugging for a while. Often this had to be repeated several times before success. The last time, aware when the power was being turned off, I shut the computer down properly, disconnected the power cord. Now power is restored, but I am unable to get the PC to come on normally or by the previous means. There is no indication of power at all as opposed to the PC just not booting up.any ideas?
  • 101 Answers
Sometimes in side the power supply over time the parts go bad a little at a time. it will work as lone as you leave it on but if you turn in off the switch mode power supply will not restart due to the parts that go bad. replace the power supply and it should be ok. there could be other things but this is the most likely.
Posted on Dec 31, 2010
Mackie ppm 608 has shut down...no lights, no sound. This is the second time in several months. Last time it was the power supply...the tech who repaired it said he has done several just like mine. The...
It has not got a complicated power supply. I don't understand why it would take 5 weeks to repair. Parts are available from Mouser/Farnell/RS etc.
Repairs would not be expensive. Replacement is another story but a competent engineer will repair the faulty unit.
Sep 25, 2017 | Audio Players & Recorders
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
Engine cuts off while driving it always restart may drive for a week than it does it again yesterday when it stopped the vehicle kept cutting off until i held the key in the foward position after i...
I have a 1998 Honda Accord EX that did the same thing for several months. The longer I let it go, the more often it did it. I took it to a repair shop and found out it was the ignition switch needed to be replaced
Jan 25, 2010 | 1998 Honda Accord
Computer has power will not start up
The power-supply must output several different voltages to meet the needs of several components.
First, try a different power-supply.
Second, look at the capacitors (those tall cylinders on the motherboard, with the X cut into their silver-coloured tops). If any of them are domed, i.e., not flat, or there is anything similar to "brown-rust" on top of any capacitor, your motherboard has failed, and needs to be replaced.
Dec 14, 2009 | Acer Aspire L100 PC Desktop
It won't turn on. The TV has been intermitant for a about a week.
Hi.
Try first leaving the TV disconnected from power for several hours. Also test on a different main, eventually using an extension.
If the problems started intermittently last week, then there is probably a fault.
If there is no power at all it is a faulty power supply.
If the TV instead is in standby, then the set must be tested to find the fault.
Common faults may concern convergence, PSU, ballast board, control and signal I/O.
Here all parts for your set.
Oct 13, 2009 | RCA G27669 27" TV
Monitor often will not power up when power button is pushed. Disconnecting power for 90 seconds corrects problem. This is an intermittent problem that is occuring more frequently over time. Condition...
I think there is a problem in Monitor's Power Supply unit which integrated in the base board of Monitor. If u expertise with the service then carry on. else Pl contact a Local Service professional to solve the problem
Aug 23, 2009 | Computers & Internet
Sony vaio power up issue
hi
u carry out your laptop battery and then restart and if you find still problem, and want technician help contact http://tinyurl.com/msfzw7
Jun 20, 2009 | Sony VAIO VGN-NR160ET Notebook
Dell Dimension 5100 shuts down then reboots automatically, This is one bugger of a problem. Had continual problem with unit shutting down no rhyme or reason, cant see BSOD message off too fast. Did change...
Try rebooting to Safe Mode. Right-click on My Computer and hit Properties. In the System Properties window, click on Advanced. Then click on Startup/Recovery Settings. Uncheck Automatic Restart. Then post the BSOD Stop Code here.
Nov 18, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Pc restarting
you check power supply unit.
Mar 23, 2008 | E-Machines eMachines Desktop PC
Samsung projection TV intermittent shut-down problem
OTHERWISE- THIS SET MAY HAVE THE DREADED 1500UF POWER CAPACITOR ISSUE WHICH ARE EASY TO SEE IF YOU CAN ACCESS THE MAIN POWER PC AND VISUALLY CHECK FOR 'POPPED' CAPACITORS ON THAT PC. JOE TV
Oct 04, 2007 | Samsung - Projection TV replacement lamp...
Acer AX1200-U1520A PC Desktop Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
