Question about Frigidaire Affinity ATF7000ES Front Load Washer
My dryer will spin and then stop spining reading err68 or err4a what can this mean.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
E4A = The drying time has exceeded program time for cycle. Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes. Position cycle selector to NORMAL, temperature selector to HIGH HEAT and touch START. Check for any thing that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closetwith solid door, or bad connection in moisture sensor bar cir cuit or dirty bars. If dryer operates normally but code returns, replace electronic control.
68 = One of the keys (buttons) is stuck closed (active). Enter function testmode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists, replace electronic control
Posted on Dec 31, 2010
How do we fix spin problem for our kenmore stackup washer
spining problems notmally are caused because the clutch, the coppler motor or the timer. The timer is the more expensive one. Does spin slow enough for you to stop it wuith your hands? If it does then is not the timer.
May 27, 2012 | Kenmore Washing Machines
My hotpoint dryer has. stopped spining everything rlse is ok please help model TLS61p
Do you hear the motor running? If so then it is probably just the belt that has broken...if there is no motor spinning, then the motor may have become defective or the start capacitor may be bad causing the motor to not start
Mar 03, 2011 | Zanussi TC7102W Electric Dryer
My dryer stop working, it made a big noise and is not spining anymore, ts sounds as if it is out of place or something, and after 3 minutes it starts smelling like burn My dryer is a Maytag...
TRY SPINNING THE DRUM BY HAND. IF IT SPINS EASY, YOU HAVE A BELT BROKEN.
MOST LIKELY THE BANG WAS WHEN THE BELT BROKE. YOU NEED TO PULL THE DRYER OUT, OPEN IT UP AND REPLACE THE BELT. A SERVICE APPLIANCE REPAIR WILL NEED TO BE CALLED. - - SORRY
Feb 20, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
I have an err68? How do I repair?
E68 One of the keys (buttons) is Enter function testmode and perform key stuck closed (active). (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists, replace electronic control.
Sep 21, 2009 | Dryers
When the dryer is open the dryer keeps spining and wont stop you have to unplug it
Check the door switch. If the plunger is stuck, the dryer keeps running.
May 14, 2009 | Dryers
Dryers drum is not spining
I was having a similar problem but my dryer was about 5 years old. There are a couple of rubbery, sticky belts that wrap around the dryer drum. One of mine had come off the drum and was balled up, wedged between the drum and the dryer wall. It wanted to spin, but this "belt" was keeping it from doing so. I'm not sure why or how it happened, but I removed the portion that was gummed up and now it works fine.
Nov 25, 2008 | GE Profile Harmony DPGT750EC Electric...
Cd wheel spining non stop
ITS NOT THE WHEEL SPINNING ITS THE LASER ITS TRYING TO READ THE DISC THAT CAUSE IT TO SPIN FAST AND SLOW FAST AND SLOW YOUR LASER NEEDS A CLEAN
Jun 27, 2008 | Wurlitzer Jukebox 1015 One More Time...
Dryer not spinning
ok this sounds simple
if the dryer stopped spining there are 4 things to look at
1 the belt for dryer if this snapped the drum will stop spining
2 the dryer wheels these ware down and break off this is what helps keep dryer in a spin straight
3 this is the crucial one the motor siezed up from lack of appliance oil not being added to a regular maintenance
4 the guages has stopped working but i doubt this if it still keeps a timer going round this would not be it you dont have to run dryer to test guages just set guage to a time and see if it rotates with the time on it
the belt you can check your self by pulling down the dryer pan that will show bottom of dryer with belt if its a belt simple maytag can come out and do a replacement and maintenance on the spot
i hope this helped seeing im not there to actually see in person whats actually wrong
May 17, 2008 | Maytag LSE7806A Top Load Stacked...
Tuble dryer not spining
sounds like your drum belt broke
Dec 01, 2007 | Hotpoint NWXR473EV Dryer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
