Question about HP G60t Notebook
Screen is showing all lines, already replaced the mother board
  • wjmhebert Dec 31, 2010
    Tried to boot in safe mode, but because the screen is not working I can't see if it is truly in safe mode or not. If I boot the laptop normally and let if finish, I can then attach an external monitor and see everything.
    I just see a very light blue screen. In safe mode it is a screen that shows half white and half black
  • 39 Answers
What type of lines exactly do you see? Notwithstanding, try and change your memory(RAM). Goodluck.
Posted on Dec 31, 2010
    Genius:
  • HP Master
  • 1,274 Answers
Try and boot into safe mode, and see if that helps,tap f8 repeatedly and boot into safe mode, if it works it's a display settings problem and can be fixed in normal mode if it doesn't then i'm not sure where to go, i would bank on it being a display setting fault or new drivers need installed
  • Friendly PC Repair
    Friendly PC Repair Dec 31, 2010
    i would recommend removing the bezel from the screen, depending how many screws it should be relatively simple they're hidden behind the little foam pieces on the face of the monitor. you can re-glue them back on afterwards or depending the glue may be re-used that's on them. take out the screws and carefully remove the bezel and you should be able to bend the screen downwards and see behind it. this is where the power/video card connections are. make sure that the connections are tight and in place as they are very thin connectors and should only go in one way. i'd even go so far as to unplug them and plug them back in as it may just be a poor connection. here is a walkthrough on the procedure for removing the screen, you may get lucky and it could be the connection to the board, if it's not double check the connection on the lcd itselfhttp://www.insidemylaptop.com/remove-rep...
Only half a picture
"the vertical lines" is not correlated with the lamp
1,the interface between the mother board and DMD drive board
2,to clean the the interface with some alcohol
3,securely plugged
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 16, 2014 | Vidikron MODEL 65 Lamp
Lines on the screen
The interface between the mother board and DMD drive board
securely plugged
securely plugged
Feb 13, 2014 | Optoma DLP Projector HD23
My knocia 7222 is always jamming it says open right side cover release lever 1 and remover paper open conveyance cover 6 fix guide 5 during depress fix guide 9 remove paper the paper always get stuck by no...
close right side cover is showing on the screen display but door is closed i have already replaced the door switch and power supply board and main mother board and tray control board.kindly advise what can i do to remove (close right side cover) sin?
Tariq E-Tech E-Mail : e_tech_pk @hotmail.com
cell : 03455235670.
Mar 15, 2013 | Konica Minolta Minolta 7222 Laser Printer...
Hello, My Samsung SyncMaster 2233 shows a small box to the right bottom of the screen with some Brightness issue, I checked all my display setting as well as did the auto-adjustment, it goes for some time...
hi,
Your tvs TFT panel or the mother board have some problem. The only why to find which one is faulty by replacing the mother board. consult some one who is experience in it. becuse you have already done what you can.
ok
Jun 11, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
Dv4000 screen is on for a few seconds then goes black. Replaced screen balast and worked for 10 minutes, then went black again as before replacement. Should I replace the lcd screen?
No. The bulb is good. It could be the DC/DC invertor - that little curcuit board just beneath the in the LCD - or the video off the notebooks motherboard. - personal experiance points to that invertor
Feb 25, 2011 | HP Pavilion dv4000 Notebook
My laptop (Toshiba Satellite Pro L300 PC Notebook) Screen have wavy line. How to fix it?
I would plug the laptop into an external drive to rule out any mother board issue first. If it is still showing the wavy lines on an external drive then it is a motherboard issue. Otherwise, try reseating the cable connections from the motherboard to the display screen.
Hope that helps.
Dec 31, 2010 | Toshiba Satellite Pro L300 Notebook
Can i ask what can i do for my DS?? my DS was fallen from a high place.. and th top screen wont show anything but lines..
MINE DID THE SAME THING. SO WHAT YOU DO IS GO TO A PLACE THAT CAN FIX THAT KIND OF PROBLEM.
Aug 07, 2009 | Nintendo DS Lite
Psp screen wont work with my old motherboard
ok i know whats wron here i just need to replace the mother board
Dec 04, 2008 | Video Game Consoles & Games
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
NEED TO REPLACE MOTHER BOARD IN TUFF BOOK CF18 I NEED TO KNOW WHAT NUMBER OR BRAND OF MOTHER BOARD TO ORDER
its a proprietary Mother board. there for you need the exact replacement MOBO. with how old this one is. id say your going to want to look on ebay for one with a broken screen thats maybe been gutted and all thats left is a MOBO. cause you cant get it from panasonic heres the exact number and model you need CF18FHHZABE. but since its proprietary you cant go walking into best buy anytime soon. so ebay one that doesnt have a blown board and that should help. but for the cost it seems you could already be 1/4th on your way to a newer much faster and nicer laptop. - thnx Nathan
Jun 13, 2008 | Panasonic Computers & Internet
HP G60t Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
