Question about Federal Industries FIN-RSSM678SC High Profile Refrigerated Merchandiser Self Serve 115 230601 1 HP50
I have a Federal Industries model RSS35C-2B refrigerator display for soda bottles. Where is the refrigeration condensor coil and how do I clean it?
dididsaythat
  • 291 Answers
SOURCE: Refrigerator freezes contents
Get a new cold control for it
Posted on Sep 02, 2007
  • 327 Answers
SOURCE: Kenmore 596.73502201 Not cooling. Compressor , fan, seal ok
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Dec 19, 2008
woodchuck789
  • 4070 Answers
SOURCE: Kenmnore 253.64879405 refrigerator not getting cold
If the evaporator fan isn't working, that's probably the problem. Test here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Jul 09, 2009
jeffbvegas1
  • 520 Answers
SOURCE: Refrigerator temp is too warm
Yes it can be fixed and freon can be added. My Traulsens load up so bad on ice up top ,I let let them set overnight and de-ice totally before continuing diagnostic. Sometimes just getting all the ice off the evaporator core and thaw helps them immensly.If you are finding ice build up,increase defrost time a few minutes each cycle. These units hold the freon in the evaporator when iced causing poor freon flow and poor air flow .
Posted on Jul 24, 2009
  • 4 Answers
SOURCE: My vaccume condensor light is flashing and my
I had the same problem and evacuated the charge, vacuumed the system down, and scaled a new charge into it, it has worked fine since then
Posted on Jul 28, 2009
Thermostat on Federal RSS4SC-2B is freezing bottled drinks
sety for 39 degrees then if it still doesnt work replace it job could be done by handy-andy kind of guy but if you doubt yourself get a refrigation service not an hvac company! the refridge guy probably has a replacement on his truck.
Jan 08, 2014 | Federal Industries Retail Supplies
Refrigerator freezes sodas in the fridge part
May be simple as dirty condensor coil try looking under the bottom where the compressor is there is a coil with a fan blowing on it. Try cleaning the coil and make sure the fan is working
Aug 10, 2012 | Refrigerators
I have a sub zero 361rfd. The freezer portion is no longer cooling, however the fan still runs. Also, The refrigerator is set to the coolest temperature but I suspect it's not sufficiently cold....
Check the temperature setting Assure that there is enough room for air flow in the freezer or freezer Check for air flow restrictions in vents Test the temperature control Clean the condensor coils Check the door seals Test the door switch Test defrost heater Test defrost timer Test evaporator fan Check for a clogged drain tube Check for refrigerant leak Freezer is too cold
Check the temperature setting Test the temperature control Freezer is noisy
Hissing and popping is normal, it is the defrost heater. Check that the freezer is level Check the drain pan Check the condensor fan Check the evaporator fan Inspect the compressor mounts Freezer runs continuously
Defrost the freezer Clean the condensor coils Check the door seals Freezer starts and stops frequently
Clean the condensor coils Check the outlet voltage Test the condensor fan Test the compressor relay Test the overload protector Test the compressor motor Freezer does not defrost automatically
Test the defrost timer Test the defrost heater Test the defrost thermostat Freezer has an unpleasant odor
Remove spoiled food Clean freezer interior with a solution of h Clean freezer interior with a solution of hot water and baking soda Clean the door seals Remove breaker strips and check for wet insulation Water on floor outside of freezer
Check the drain pan If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve Water inside the freezer
Check for a clogged drain tube If you have an ice-maker, check freezer and ice-maker for level
Hoping that this will help to solve the problem....
Aug 18, 2011 | Refrigerators
I have a magic chef refrigerator model # mcbr415sf. The top freezer part does not get cold enough to keep ice cream cold, but when you turn the temp up -- there is only one temp control and that controls...
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
You can fix this by yourself and do take care in solving the problem......
May 12, 2011 | Refrigerators
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
I have the same model HDC3655. My problem is
Mould is a bacteria
Clean out the unit and wash the area with a strong soda solution.
Also wash the bottles which will carry the same bacteria
Dry throughly
Dec 31, 2009 | Franklin Industries FBC360D Beverage...
Looking to buy a condensing fan blade for a federal industries display unit
go to a heating/plumbing/air-con place or elect supply with unit number or model number off fan-if have old damaged on not better can use to compare for replacement with a universal unit
Oct 05, 2009 | Federal Industries (CGR3642) Commercial...
Not cooling enough per the display
I have this same model which I think I bought in 1988. My frig was overheating also and the compressor was extremely hot. I too cleaned the condensor coils again and have been cleaning them at least annually for a decade and a half by putting an adapter on my small vacuum cleaner. This time I took my 6 hp shop vac and a long bottle brush and scrubbed the coils clean running the brush over the coils many times and using a trouble light to help identify where all the accummulated dust was. Frig is working perfect again. Exhaust temperature is substantially reduced. Hope this helps.
Apr 30, 2009 | Kenmore Refrigerators
Subzero model 650 needs the condensor cleaned
The best way to clean the condensor coils on this model is to blow it out with an air tank.
Jan 07, 2008 | Refrigerators
Federal Industries FIN-RSSM678SC High Profile Refrigerated Merchandiser Self Serve 115 230601 1 HP50 Logo
81 people viewed this question
Top Federal Industries Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Federal Industries Refrigerator Expert? Answer questions, earn points and help others
