Question about Miele Touchtronic W1213 Front Load Washer
W1213, pre-wash and main wash lights flash with the 3 lines --- fault code. I tried entering the service mode as I read online I should push and hold start, then turn on the machine, wait for the dot and push start 3 times, holding on the third. Although there were no letter F's, three numbers alternated! A 5, a 9, and a 1 flashed, one at a time. please help!!!!
You are in the service mode now. The buzzer LED displays a flashing rhythm of 2 flashes while the ROM ID is show in the display(this is what you are seeing), press the buzz button to advance to the fault register level. Here is the manual to the tech manual http://laundry.manualsonline.com/mdownloads/89c212d9-4843-4409-b17c-b3439c9b0d05.pdf
Posted on Feb 21, 2011
  • davidh41 Feb 21, 2011
    if you have an f065, trying tightening the door light..inside the door at the top..use the flat orange (or could be yellow maybe) tool that in on the inside of your dispenser tray. Look at the operating/installation manual that came with your machin on page 29 about bulb replacement. I kelpt getting the --- and found fault code was f065..so i just tighten it and solved my issue.
Will not pre-flash
it sounds like you are try to SEE the pre-flash. you'll never be able to do it with bare eyes. it's all so quick that to the human eyes it all looks instant. don't worry about it. if it working in TTL mode, it does all the pre-flashes it needs, you just to see them. speed of light is quite incredible :)
Dec 04, 2011 | Canon Speedlite 430EX TTL Flash
False empty toner reading
The problem can be may this however hard resetting it can fix the issue
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Jul 12, 2008 | OKI C5500n Printer
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Check engine light for volvo 850 wont go off wat else can be the problem if i got a full tune up and put in new spark plugs plus it trembles alot and it shakes when i start it up plus wen i put it on...
Hi, I recommend you access the OBD panel to extract the trouble codes. Then send us the trouble codes for further advice. On 850 models the DLC is located in the engine compartment in front of the module box, behind the passenger side headlamp.
  1. Open diagnostic socket cover and install selector cable into socket No. 2 for fuel injection codes or socket No. 6 (except Motronic systems) for ignition codes.
  2. Turn the ignition switch to the ON position.
  3. Enter control system 1 by pressing the button once. Hold the button for at least 1 second, but not more than 3.
  4. Watch the diode light and count the number of flashes in the 3 flash series indicating a fault code. The flash series are separated by 3 second intervals. Note fault codes.
1f there are no fault codes in the diagnostic unit, the diode will flash 1-1-1 and the fuel system is operating correctly.
  1. If diode light does not flash when button is pressed, or no code is flashed there is a problem with the soft-diagnostic system, proceed as follows:
    1. Check ground connections on the intake manifold, and the ground connection for the Lambda-sond at the right front mudguard.
    2. Check the fuses for the pump relay and the primary pump. On 240 models, fuses are located inside the engine compartment on the left side wheel well housing. On 760/780 models, fuses are located in the center console, just below the radio. On 740/940 models, fuses are located behind the ashtray. Access can be gained by removing the ashtray, and pressing upward on the tab marked electrical fuses press. On 850 models, the fuses are located on the left side of the engine compartment behind the strut mount plate. The fuses on 960 models are located on the far left side of the dashboard. The driver's door must be open to gain access to the fuses.
    3. Remove glove compartment, and check control unit ground connections.
    4. Turn the ignition switch to the OFF position. Remove control unit connector and connector protective sleeve.
    5. Check diagnostic socket by connecting a voltmeter between ground and No. 4 connection on the control unit connector. Reading should be 12 volts. If no voltage is present, check lead between control unit connector and fuse No. 1 in the fuse/relay box.
    6. Turn the ignition to the ON position, and install selector cable into the No. 2 socket on the diagnostic socket. Connect a voltmeter between ground and No. 12 connection on the control unit connector. Reading should be 12 volts. Press the button on diagnostic socket and note reading. Reading on the voltmeter should be 0 volts. If no voltage at the control unit is present, take reading at the diagnostic socket connector. If reading remains at 12 volts when button is pressed, check diagnostic socket.
    7. Connect a voltmeter between ground and the red/black lead on the diagnostic socket connector. Reading should be 12 volts.
    8. Connect a suitable ohmmeter between ground and the brown/black lead in the diagnostic socket connector. Reading should be 0 ohms.
    9. Turn the ignition to the OFF position. Connect ohmmeter between diagnostic socket selector cable and the pin under selector button. The ohmmeter should read infinity. Press the button and note the reading. The reading should be 0 ohms.
    10. Connect a suitable diode/multimeter tester, or equivalent, between the diagnostic socket diode light and the selector cable. Connect red test pin from the tester to pin under diode light and black test pin from tester to selector cable. A reading on the tester indicates correct diode light function. With no reading on tester, replace diagnostic socket.
    11. Check the system relay/primary relay by connecting a voltmeter between ground and the No. 9 connection on the control unit connector, then connect a jumper wire between ground and No. 21 connection on the control unit connector. The relay should activate and the reading should be 12 volts.
  2. Press the diagnostic socket button. Note any additional fault codes.
The diagnostic system memory is full when it contains 3 fault codes. Until those codes are corrected and the memory erased, the system cannot give information on any other problems.
  1. Press the diagnostic socket button for the third time to see if a third fault code is stored in the memory. If the diode light flashes the same code 1-1-1, there are no other codes in the memory.
Fig. Fig. 1: Push button once for mode 1
Push button twice for mode 2
Push button three times for mode 3
To clear the codes:
  1. Turn the ignition switch to the ON position.
  2. Read fault codes.
  3. Press diagnostic socket button 1 time and hold for approximately 5 seconds. Release button. After 3 seconds the diode light should light up. While the light is still lit, press the button again and hold for approximately 5 seconds. After releasing the button, the diode light should go off.
  4. To ensure that the memory is erased, press the button 1 time, for 1 second but not more than 3 seconds. The diode light should flash code 1-1-1.
  5. Start and run engine. If engine will not start, correct the problem before proceeding and start over with Step 1.
  6. Check to see if new fault codes have been stored in the memory by pressing the diagnostic socket button 1 time, for 1 second but not more than 3 seconds.
  7. If fault code 1-1-1 flashes, it indicates that there are no additional fault codes stored in its memory.
Oct 05, 2011 | 1994 Volvo 850
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
Indesit wie157s - H2O fault, prewash water ok but no main water
this is just a guess, but try changing water temp. settings for main wash- perhaps one of your water inlet valves is clogged or defective?
good luck!
Apr 17, 2010 | Washing Machines
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Blinking lights on Front Panel
I've finally tracked down the manual and it the fault code is as follows
"Indicates a fault in the heater or in the thermistor"
You can go into a fault tracing mode by pushing the "Rinse Hold" button five times within 15 seconds. The first, third, fifth and seventh lights will flash when in this mode and you can test the following parts by pressing the corresponding button. I'm going to try the heater test below and assume that if that works the fault must be with the Thermistor. The other tests could be useful for other faults.
User manual found here
Rinse Hold - tests detergent solenoid, detergent flaps open after about 60sec
Pots & Pans - tests Rinse Aid Solenoid, rinse aid will flow down door
Normal Wash - tests water inlet valve, water can be heard entering
Light Wash - tests ventilator solenoid, there will be a click followed by a rattling noise
Quick Wash - tests the heater, the element heats up, WARNING don’t touch element HOT
Temp - tests circulation pump, the pump starts
Dry - test outlet pump, the pump starts
Manual says to push 55 and 65 degree button to exit, I have no idea where those are so will probably just switch off at wall to reset.
Hope this helps someone. I rang ASKO and they said they didn’t know what the fault code meant so either they can’t read or their service sucks, probably a bit of both!
Feb 12, 2009 | Asko D1716 Built-in Dishwasher
Miele Touchtronic W1213 Front Load Washer Logo
430 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
