Question about Sony PlayStation® 3 (60 GB) Console
I just bought grand turismo 4 and after the console has been running for a whlie the machine is just crashing and the red standby light flashes. After a few seconds I can restart the console with seemingly no trouble at all. This has never happened before so could it be a cooling issue?
  • 21 Answers
It is possible,make sure all your vents are claer of dust,use a hoover all around it and make sure you have plenty of room for it to get air
Posted on Dec 31, 2010
I have a 55" sony
According to the manual (you can see it here) page 122 that describes 3 red flashing lights:
"The lamp cover is not attached securely. When you secure the lamp cover, the POWER / STANDBY light flashes in red and the LCD projection TV enters the standby mode (see page22)"
Page 22 says:
"... if the POWER / STANDBY light flashes continuously, this may indicate the display unit needs servicing..."
Most DLP displays make use of a "color wheel". These small motors spin at many thousands of RPM. They often begin to make scratching sounds when they are beginning to fail. Some manufacturers make it difficult to change yourself - and others make it pretty easy.
I hope this was at least a good starting point for you & good luck. Please rate my reply. Thank you.
Apr 04, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
My playstation 3 crashed when i was playing gran turismo now it wont turn on and theres a yellow light then a flashing red one
If ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
still the same problem,don worry check out the following Repair Guide.....
Click here to download repair guide
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
I can't operate any games in 2 player mode
Many games require original PS2 dual-shock controller. Make sure that you have original controllers.
Jul 10, 2010 | Sony PlayStation 2 (PS2) Console
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
I have 3 flashing red lights on the console and a yellow light on the power supply
3 red flashing lights is known as the red ring of death. Your power supply showing a yellow light is ok, that just means that your power supply is on standby. The first thing you should do is check with microsoft to see if your unit is still under warranty with this site: http://support.xbox.com/support/en/us/xbox360/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/xbox360/registerdevice.aspx?step=repair
If your unit is not under warranty, go to www.wiredextreme.com. We are a console repair company based in Texas, and we can fix your console. We give a free diagnoses on your unit(excluding shipping), and will call with an estimate before any work is done on the unit. All our work is covered by a 90 day warranty, and you can buy up to 4 years worth of warranty coverage.
Nov 16, 2009 | Microsoft Xbox 360 Console
PS3 TURNS ON,GREEN LIGHT FOLLOWED BY YELLOW LIGHT THEN RED FLASHING LIGHT,FANS COME ON BUT WITHIN 3 TO 5 SECONDS ALL SWITCHES OFF TO A RED FLASHING LIGHT
Your hardrive has probably crashed. I have been trying to fix mine and after weeks of studying, i found out I need a new video card. If you have demos then my problem may be yours too. If you are trying to play games and it crashes, then it's the video card. The only game that works with a broken video card is Street Fighter 4, but you can't save. Visit this link for better instruction on how to fix non-video card problems. I hope it helps!
Sep 05, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360
Unfortunately this is a very touchy situation. There is one home method for curing this problem.
1). Wrap your Xbox 360 Console COMPLETELY with a towel, so you can only see the power button, and the three flashing red lights.
2). Power on your console.
3). Leave for 30-45 minutes.
4). Power off the console.
5). Unwrap the towel from the console.
6). Power on.
**Problem Solved** If not continue reading.
After that you are unfortunately forced to call the dreaded Microsoft Customer Support Line
1-800-4-MY-XBOX
1-800-469-9269
And ask to create a repair order, they will send you a Purolator (or FedEx) shipping box. You have to send your console to them, they will repair it and have it to you within (2-3 business weeks).
Nov 13, 2007 | Microsoft Xbox 360 Console
Sony PlayStation® 3 (60 GB) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
