Question about Sansui RZ-5200AV Receiver
I am fixing a sansui rz-5000av receiver /amp. the problem is the power supply,it does not switch on. the fuse is fine, capacitors are all ok. But power does not reach connector for the standby supply to switch amp on. Please help
  • 2,760 Answers
Ive seen this happen before on sansui a/v amps , seems they have an accessory outlet on back that triggers with power switch (for other items power) well sometime in its past someone plugged something larger than the 500 watts its rated for (ac) load into it and now the traces on printed ckt board are fried , on yours id bet if you look carefully at bottom of main ckt board right in area that power cord connects to it , you have a similar problem , me I fixed mine with a little piece of used solder wick to bridge the gap in traces
Posted on Oct 22, 2015
    Brigadier General:
  • 8,546 Answers
So you're saying ac doesn't get very far into the unit. THAT should be easy to diagnose with CARE since ac is usually passed unmodified to the fuses and power supplies, maybe through a relay. Get a digital voltmeter and find out where it disappears after getting into the unit.
Posted on Dec 31, 2010
  • tsakani_co_z Jan 04, 2011
    The ac is there and is converted to dc.The dc goes as far as the relay coil and after that its not there. In order for power to be there the relay must be pulled to ground, but it does not do that
  • David Dunn
    David Dunn Jan 04, 2011
    Right, the relay needs to be activated based on some kind of go/no-go safe-condition-sensing circuitry. Dead shorts, excessive current or NOT all voltages safe would drop or prevent picking the relay.
    One or more of the necessary voltagesor conditions to power the relay coil could well be missing so pulling it to ground to simulate activation might accomplish nothing overall if that same voltage or condition is vital somewhere else in the amp.
    If you can identify the 'safe' signal that the relay passes you COULD just jumper past it and monitor the panel for life. If it lights up then the relay pick circuitry and conditions that enable it are suspect. If it doesn't light up, we're back to square one.
    Of course, this is all risky stuff. Be careful.
I have an older (10 ) years Sansui am/fm receiver model rz-5500av. It performs well, but after a power surge, the fm radio will not play in stereo. The fm stereo indicator flashes on and off. I was told...
Part of the circuit is a stereo multiplexer decoder, that decodes the fm stereo signal, I guess that is what you mean when you talk about capacitor linked to the fm band.
I do not have the sbchematics for this circuit, if you are good at electonics just grab the tester and check the whole circuit. On a radio is not difficult to find a blown capacitor.
Test also the stereo/mono switch.
Sep 21, 2008 | Sansui Audio Players & Recorders
My Sansui model hdlcd3700 has sound but no picture at the power on, the back light flashes once. my question is power supply or or inverter?
first of all you have to check the power supply. sometimes bad electrolytic capacitors on the power supply can lead to such problems. may the capacitors seems ok visually but not be good in performance. if power supply is ok then you have to go for a ne inverter board. check the video to understand how to check the power supply of lcd tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent
Testing LCD TV Power Supply BoardsSTEP BY STEP
Nov 11, 2015 | Sansui Televison & Video
Sansui mdl hdllcd3210 will not turn on.
Did power signal lights appear?If there's no power signal lights,check the fuse,located at the power supply.If the fuse is good,maybe the power supply is dead.There's a leak capacitor in the power supply.Try to replace all the leak capacitor..The leak capacitor can identify through visual checking when you didn't know how to use tester.The leak capacitor is rounded top shape and have moise at the top,compare to flated shape of good capacitor.Thanks,hope will it help you..
Aug 26, 2011 | Sansui 32" TV
I have a 1975 Sansui Integrated Stereo Amplifier and Left Channel on System A & B are faint and Tinny as if Left Channel in System went out. I swapped speakers from right to left channel and same...
It's likely there is a fault on the power amp. This is located on the heatsink. A visual check inside the unit might be what you need. Look out for blown parts, bulging capacitors or burnt components. Remember the two channels are generally separate and identical. So identify the two channels. Work back from the speaker sockets if you can't tell. Then compare the left channel parts with the right side components. If it looks odd on the left compared to the right you have found the problem.
Feb 14, 2018 | Sansui RZ-5300AV Receiver
I have a sansui stereo av receiver rz 7000 from 1990 which works on 110 220 230 volts and the receiver has a voltage selector on the back - I need to understand how to move the selector from 220 to 110...
Remove the fuse cover with a flat screwdriver, then pull the surrounding circular black plastic piec straight out and reorient it to show the desired voltage, then plug it in, insert the fuse and cap.
Nov 24, 2010 | Sansui RZ-8150AV Receiver
Sansui Amp
Bad supply capacitors...accordianman
Mar 09, 2008 | Audio Players & Recorders
No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Feb 01, 2007 | Sansui RZ-5300AV Receiver
516 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
