Question about Brother Office Equipment & Supplies
Says drum error, see troubleshooting maitainance chapter in user guide. Don't have a users guide. Printer is brother mfc-7340
  • 488 Answers
I have this manual for you. I can be reached at LBrown18062@hotmail.com
http://welcome.solutions.brother.com/bsc/public/as/as_ot/en/doc/manual_index.html?reg=as&type2=-1&prod=mfc7340_us_as&c=as_ot&lang=en&flang=all
Drum Error - The corona wire on the drum unit needs to be cleaned.
Clean the corona wire on the drum unit. (See Cleaning the corona wire on page 122.)
Cleaning the corona wire: If you have print quality problems, clean the
corona wire as follows:
a. Turn off the machine's power switch.
Unplug the telephone line cord first, disconnect all cables, and then unplug
the power cord from the AC power outlet.
b. Open the front cover.
c. Slowly take out the drum unit and toner cartridge assembly.
CAUTION: We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
To prevent damage to the machine caused by static electricity, DO NOT touch the electrodes shown in the illustration.
d. Clean the corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times.
CAUTION: Be sure to return the green tab to the home position (a) (1). If you do not, printed pages may have a vertical stripe.
e. Put the drum unit and toner cartridge assembly back in the machine.
f. Close the front cover.
g. Plug the machine's power cord back into the AC power outlet first, and then reconnect all cables and telephone line cord. Turn on the machine's power switch.
Posted on Dec 31, 2010
Drum error:
What is the drum error?
Jan 27, 2014 | Brother MFC 890 InkJet Printer
Drum Error - see routine maintenance chapter in user guide. Do not have user guide
I tried everything and then decided to slightly change the above instructions to:
press Clear/Back
Replace New Drum - select "Yes"
after the screen will show "accepted"
close the front cover and you are good to go
and WA LA it worked!!
Apr 19, 2011 | Brother MFC-7340 All-In-One Laser Printer
Unable to clean see troubleshooting and routine maintenance chapter in user's guide
unable to init. see troubleshooting and routine maintenance chapter in user's guide - printer: DCP- 115c
Jan 30, 2011 | Brother Multi-Function Center® MFC-215C...
Drum error
With that error you need to remove the drum, run the little blue tab on top back and forth about 20 times, blow out the area below the blue tab, and re install and try printing again. If the error is drum life end you need to open the front door and press either menu or options, sometimes the clear/back button and tell it it's a new drum.
Dec 30, 2009 | Brother MFC 7840W Printer
Printing after being on same phone line as printer/fax
This link will open the Users Manual, but you will need a PDF viewer such as Adobe Reader or Foxit Reader in order to open it.
Go to page 12-4 in Chapter 12, Troubleshooting and routine maintenance. Follow the actions recommended for the Unable to clean error message (and the four other Unable to... error messages).
Jul 04, 2008 | Brother MFC-3240C All-In-One InkJet...
PRINTER SAYS UNABLE TO PRINT USER'S GUIDE CHAPTER TROUBLESHOOTING
This is a common problem. If this is under warrenty get it repair or exchanged. There is a lot of people on here that are having the same Problem
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
324 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
