Question about ATI RADEON HD 2400 PRO Graphic Card
I need a new motherboard, which will accept my Athlon 64 754 pin and my HD 4650 1gb card plus 2xsata and 2xpata hdd,your help please ericj
  • eric jenkins Jan 02, 2011
    many thanks drifterK, I am taking your advice and going for Epox EP-8HDA5+ just have to find one in uk
    regards
    ericj
  • 4,924 Answers
I use AMD Athlon x2 proccessor, Ati Radeon HD 4530 (512 MB) Graphic Card and a 2gb ddr3 RAM. My graphic card works fine in the beginning. But later, when i turn on my pc, the monitor remains black and no...
Hello there!
I am very experienced with this problem,yet there is a simple solution.Basically,your pc is doing a great job,it is preventing your card from damaging.
Why does it turn off? Simply because your graphic card is over heating.Try to get some thermal paste(google) or some new fans.A water cooling system would help aswell.
Another solution:
It can be that you are not inserting your monitor's VGA cable in the graphic card's slot,thats the important part.
I hope this helps!
Apr 20, 2013 | ATI RADEON HD 4350, (512 MB) PCI Express...
I just installed a BLKD915GVWBL LGA 775 Intel 915GV Intel motherboard in a new computer i'm building. everything powers up but no video. i have tried 3 different moniters. what's the problem?
You need to perform a quick check of the following steps for us to understand the exact status of your SMPS(power supply) and Motherboard
1) Open the CPU and check whether the green light is glowing on the motherboard when power is given to SMPS.
2) Please make sure that the HDD IDE/SATA and power cables are plugged in properly on both ends.Use common sense to check, do not press very hard as the slots are sensitive.
3) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
4) Make sure that the Jumper setting on the back of the HDD is set to MASTER. NA for SATA.
5) Remove any VGA/Graphics card that you have installed. Also remove any PCI cards that you have installed.
6)Connect the monitors VGS cable to the Blue 15 pin female VGA out port of the motherboard.
7) If possible login to bios and make see if you can find the HDD from the drives menu. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels.
If you feel that, my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Note: Please click on ' Accept' to accept my answer because it is your Acceptance, which gives us motivation to assist you with more efficiency.
Mar 11, 2012 | Intel D915GVWBL Motherboard
Cant seem to get right the pin connection on the morther board for power,hdd.
One corner of the motherboard will have a grid of pins.
Two adjacent pins will be labelled 'PWR' or 'POWER'.
Two adjacent pins will be labelled 'HD' or 'HDD' or 'HD LED'.
Dec 20, 2010 | Computers & Internet
Trying to install a Samsung PATA 160GB HD in my recently bought ued Solo 5300.I see no cables etc, just some pins at the back of the HD slot. Do I need to take the whole unit apart to get at any cables?...
larry, is your motherboard PATA capable? meaning, are there 4-8 red female connectors on your motherboard?
If there is no compatibility with your PATA/IDE Motherboard, you can purchase at any local computer shops PATA-IDE converters... ranging $15USD.
This converts the PATA DATA+Power to your motherboard.
The HD you have requires Jumpers. Hence why they look like card slots on the back.
Before purchasing any cables, be sure to notice if your motherboard is PATA capable and relieve less stress on you :)
Aug 27, 2009 | Gateway Solo 5300 Notebook
Fast processor's speed
Your motherboard accepts Socket AM2 for AMD Athlon™ 64FX / 64X2 / 64 and Sempron processors
The board has safe overclocking - so unless you know what you're doing I would stay away from changing any settings manually or you could fry the mobo.
How much memory do you have - more memory can increase speed. Faster HDD
If you want you could go for the Athlon 64,
The Sempron only goes to 2.31 so there wouldn't be much difference in speed.
Apr 25, 2009 | Computers & Internet
My MB does not accept 2 devices on IDE at the same time
ok
first i assume that your hdd is in master.then take your dvd then see in bbback side u find three pin .put jumper in second pin.
also read instuction on hdd and dvd some times there are defference in manufactureres policy.
Nov 14, 2008 | Intel DG31PR Motherboard
K8 Neo-2 V-2.0
Please connect jPw1 to 4 Pin 12v, this supplies power to CPU. Than enter Bios & find Boot settings. Set the cdrom as boot 1 & hd as boot 2. Check the jumper on the cdrom, as it is the only device on secondary IDE controller it should be set as a master.
It is better to install a fresh copy of windows with a new motherboard. Put your windows CD in the cdrom & the system will boot to it. And your on your way. You can install the drivers for the board after windows has been installed.
Enjoy!
Plaease vote..
Dec 05, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
My system doesn't see 500GB HDD (SATA) (Seagate Barracuda)
Can you see this HD in:
Control Panel/System/Device Manager?
In Computer management?(Rt.Click My Computer/Manage/Disk management)? You can also format the disk here.
Oct 14, 2007 | Soltek SL-75FRN2-RL Motherboard
Syntax motherboar error beep code
you may need to reset the cmos on jbat1 terminal with the jumper across pins 2-3 then back to pins 1-2, then boot up and reset time,date and hdd, press f10 to save and exit. this is all assuming your board supports the sempron processor as well as the athlon
Mar 26, 2007 | Syntax SV266AD Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
ATI RADEON HD 2400 PRO Graphic Card Logo
82 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
