Question about Pitney Bowes C180 Copier
Pitney bowes c 180 copier red wrench error - Pitney Bowes C180 Copier
  • 1,110 Answers
The red wrench is a maintenance indicator. Your Pitney Bowes C180 is made by Panasonic and is a model FP7718. I was going to type up the maintenance reset procedure but I will just give you a link to a page that has step by step instructions. Here it is:
http://www.copytechnet.com/forums/panasonic/6754-panasonic-fp-7718-maint-counter-reset.html
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Dec 31, 2010
Pitney Bowes FD40 error top cover open
Locate the top cover switch that is apparent stuck in the open position. Fix or bypass it.
Oct 20, 2016 | Pitney Bowes Office Equipment & Supplies
I have a pitney bowes C180 that won't copy. The
the little wrench means it has shut down because it has exceeded the maintenance count, probably for the cleaner web in the fusing unit. Call service at 1 800 243 5556
Oct 30, 2009 | Pitney Bowes C180 Copier
Pitney Bowes DI425 deflector error.
Error 26 is referred the explorer can be in favor heavy of dirt, which causes that it does not have the suitable speed of return. Clean and you lubricate the zones of work of the to explorer.
Sep 14, 2009 | Pitney Bowes C180 Copier
Pitney bowes model c400 copier error 0070??
Sincerely,I don`t know this model,but the error codes is similary to the Agfa,Minolta,Konica copiers.This code is the toner agitator motor malfunction code.The developer station is blocated under minimal level of toner ratio.In this case forced toner supply.Opem amd close the front door to reset.
Aug 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Jan 19, 2009 | Pitney Bowes C180 Copier
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Jan 05, 2009 | Pitney Bowes C180 Copier
PITNEY BOWES C180 COPIER
Contact OCE to find a dealer in your area. There the ones handling service on Pitney Bowes copiers.
Jul 29, 2008 | Pitney Bowes C180 Copier
Pitney bowes 9720 error
I've never heard of that type of error. After going through Pitney Bowes vast database, the searches turned up with nothing worthwhile.
Do you have any other information I can use to further assist you?
Please let me know if this helps. Good luck!
Feb 29, 2008 | Pitney Bowes 9920 Plain Paper Fax
My copier powers on without errors but doesn't copy
hi im jules_09,turn it off first then turn it on for a 5 sec.try using a automatic voltage regulator
Oct 02, 2006 | Pitney Bowes C180 Copier
207 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Victorman
Victorman
richie46
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
