Question about LG W2361V-PF 23 in. Widescreen LCD Monitor
I just bought the LG W2361 i've connected it to my computer via a hdmi cable and have plugged my headphones into the correct slot in the bottom of the monitor, i've tried turning up the volume using the controls on the side but still cant hear anything :s
3 Suggested Answers
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
stonephoenix
  • 563 Answers
SOURCE: Tv to DVD
If you know it isn't the component at the other end of the HDMI cable, then the TV likely needs to be repaired. There are only a couple of HDMI issues that can be addressed with any type of in-home troubleshooting. To be sure, call LG tech support at 800-243-0000. If there is anything that can be done without having the unit repaired, they will be able to tell you what that is.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
Connection to PC
I have had the same problem. If you have a VGA cable shown at the bottom. You can hook that into your laptop into the TV. The slots look like a blue incovering. You can also look at the image below that one for more additional help....
images?q=tbn:and9gcsiv-gyi4jh5l6apvblrydzbiwzndoskvj3ytpifllclwa1qmks
images?q=tbn:and9gctjzjmvlnbu_yfg04yh87cl2mau36aexgpvkl7rwz0yczn0azmwaq
Jan 29, 2014 | LG RZ23LZ55 23 in. LCD Television
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Connect hp laptop to toshiba led tv using vga and audio jack
hi,
I think you need a headphone to rca adapter. your outputting to an output. the output from the laptop has to go IN to the back of the tv to the input next to where your video input is.
Jul 02, 2017 | Toshiba 46TL963B 46 inch full hd led tv...
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
Which accessories are a 'most have' for connecting my TV to a desktop pc?
You'll need:
•VGA cable
•S-Video Audio to 3 RCA Type Adapter Cable
•HDMI cable
•DVI cable
Check the connection options on your TV. If your TV has a VGA connection slot, plug the TV into the computer with a VGA cordlike a computer monitor. Connect one end of the VGA cable to the back of the computer and the other end to the TV. Switch between normal TV viewing to displaying your computer on your TV by selecting the proper mode from the remote control, some remotes will mark the proper mode as "VGA" while others will label it "Computer" or "PC."
Check the back of your computer to see if you have an S cable slot. Connect S cable portion of the S-Video Audio to 3 RCA Type Adapter Cable to the computer and plug in the green audio plug to the audio port of the PC. Plug the red white and yellow RCA cables into the matching colors of the RCA slots on the TV. With this method you will need to switch modes from TV to video.
Check the back of the computer and TV for either DVI or HDMI slots. The slots on your computer must match, you cannot connect a DVI to a HDMI. Plug one end of the corresponding cable into the the back of the TV and the other end into the computer. Choose the correct program mode, HDMI or DVI, from the remote to view the computer from the TV.
Aug 12, 2010 | Televison & Video
I have an 52 inch lg5000 tv . it supposed to be full hd. i ve tried to connect my play station 3 via hdmi cable but the only thing i get is the no signal sigh on the screen i ve tried everything . is my tv...
plug the ps in with power cable only no hdmi. When turning on Hold down the power button until you hear a second set of beeps you have now reset the video settings. Turn the console off and plug in your hdmi and switch back on it should now work.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
No Xbox image via HDMI
the only thing i can think of is that you havent flicked the switch on the hdmi cables wher the plug into the xbox from tv to hdmi, if you have the go ahead and get it replaced
Jan 04, 2010 | Microsoft Xbox 360 Elite Console - Black
LG HDMI problem
have you found the solution for this problem because i have the some problem with my tv??
Oct 07, 2009 | LG 32LG30 32 in. LCD HDTV
Cant tune ps3 to lg tv
Be sure you have the HDMI cable in the correct slot for the input channel you are trying to connect. Try another input channel like HDMI 2, 3, or 4 depending on how many channels you have. If you have another TV with HDMI, try plugging it in the other one to see if it is a problem with your TV or the PS3.
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
LG W2361V-PF 23 in. Widescreen LCD Monitor Logo
172 people viewed this question
Computer Repairing
Computer Repairing
