Question about Refrigerators
The bulb did not work in the fridge area - have tried to replace with 3 bulbs and it still is not functioning. We thought maybe a fuse had gone but cannot find where this would be. The freezer light is working perfectly.
    Problem Solver:
  • 17 Answers
Replace door switch its faulty
Posted on Dec 31, 2010
Has the fuse blown on my machine? It doesn't turn on anymore. I changed the bulb and accidentally put in a 25W instead of a max 15W and it turned on for a few mins until i started sewing and it cut.
Hello Jess
Your manual is listed below, but I don't see a fuse or a reset button at a quick glance.
However, open up the area where the bulb is and look for a reset button. Also look on the foot pedal. Plug something else into the wall outlet to verify that a breaker hasn't tripped.
Did the machine work with no bulb alight? Wondering if the bulb must be working and present for the machine to function for safety reasons?
You know there is an On/Off switch above the power cord on the back of the machine, PAGE 6, Figure 1 in the manual?
http://www.singerco.com/uploads/download/38b237687d4dcaa62be10a78bb352508437b5509.pdf
Jul 02, 2016 | Singer 2250 Tradition
Prius headlights work only on highbeam
There should be separate fuses for high and low beams on a Prius. If one of your headlight bulbs is bad, it could have blown the low-beam fuse. Check for blown fuses behind driver's side headlight fuse panel. If new one blows, replace headlight bulbs and try again.
On 2004-2009 Prius, driver's side headlamp bulb can be replaced by removing hold down screws and folding fuse panel upward to access rear of headlight assembly. Large round cover with 3 tabs unscrews about 1/4 turn to remove. It's really tight and held by friction of large O-ring so it'll take some muscle but it will eventually give. Be careful replacing bulbs as metal clips can be easily installed incorrectly resulting in tilted headlight beam. 3-tabs must rest on flat surfaces on mounting area before spring clip can be latched in place. 3-prong plug can be wiggles sideways/up and down to remove from bulb.
Oct 24, 2013 | 2006 Toyota Prius
Headlight fault
You may have blown a fuse, check fuses first then before you try to replace the bulb again check for broken wires or the correct bulb
Oct 25, 2017 | 2008 Kia Pro-ceed 1.6
2006 Dodge Caravan the right rear blinker has gone out. I have changed the bulb as well as the fuse. The blinker on the dashboard blinks rapidly. Any clues on what I should check next?
Check to see if the grounding wire is still attached. The rapid blinking on the dash is an indicator of a bulb not functioning. You can have the power to the bulb and the bulb be ok, but if you don't have the circuit completed with a properly grounded wire from the bulb, you won't get a light... that sounds like what's happening.
Look in the area where the wires connect and check for a loose connection. It's usually attached to a screw in the local area of the socket...
Mar 11, 2010 | 2006 Dodge Caravan
2003 BMW R1150RT Headlight (low beam) does not work
Headlight relays..1 for low 1 for high..These are most time under gas tank.Might be also located on battery box
Jul 21, 2009 | 2003 BMW R 1150 RT (ABS)
Beeping Noise/Blinker Noise
sounds like your electronic flasher unit maybe stuck causing the noise. they are generally located under the dash on driver side just below the instrument cluster.
Sep 10, 2008 | 2004 Oldsmobile Alero
I used a GE Helical 13w 12oVAC 60Hz 200mA FLE13HT3/3/SW bulb for the top light in my fridge and it only lasted for about 3 to 4 months. Is this do to the cold in the fridge or maybe the door being opened...
You should use a standard 40 watt appliance bulb (usually clear). The life of compact florescent bulbs is greatly shortened by turning it on and off frequently. They work best being left on for 15 minutes or longer. Cold temperatures can also shorten bulb life as well.
Jun 17, 2008 | GE Refrigerators
Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Dec 05, 2007 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
