Question about AEG Lavamat 12710 Front Load Washer / Dryer
Aeg lavamat starts then stops and start light flashes
SOURCE: Washing Machine Fault Code
motor problem get new motor
Posted on Mar 22, 2007
  • 249 Answers
SOURCE: AEG lavamat 6955 showing F9 on display panel
unplong machine and restart it .eamonn eire thank you
Posted on Jan 26, 2008
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
SOURCE: aeg 76669 oko lavamat machine not
can you switch back to off - then to orginal programme - only the start light may show - what i did then was press all of the 4 button for rinse, spin short wash and held them in place - fro upto 10 secs - machine seemed to reset itself and it worked
Posted on May 19, 2008
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
Cycle won't start/start light flashing red
Probably a bad wax motor in the door switch or a bad control board.
Yeah you should call someoneif you're not a learned handyman.
Feb 06, 2014 | AEG Washing Machines
AEG Lavamat W1450 Electronic - after about 10 mins of programme machine is making beeping sound and stopping
this is an errorcode !
try to download a servicemanual,
then you can figure out the exact failure -
like : does not heat up etc. ....
May 05, 2012 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat E1050 End light blinks 5 times.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
(Companies just want you to dump the machine & buy another, its keeps them in business)
Jun 01, 2008 | AEG Lavamat W1050 Front Load Washer
Jan 26, 2008 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat w1450 electronic.
Try:
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Nov 12, 2007 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 12710 Front Load Washer / Dryer Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
