Question about Locks & Locksmithing
I cant open my Antler suitecase. its a comantion lock and I cant remeber if I set the lock or not. I have tryed all the possible numbers that I am likely to set it as but they dont work. I have tryed 000 which I belive is the orginal number that they are set at when bought? Can any one help please? Thanks
SOURCE: Set luggage lock
the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
Posted on Jan 03, 2009
alpug
  • 1961 Answers
SOURCE: I have a new Nubbio
You can not reset your lock combination without knowing the original combination you had set.
If you have forgotten your lock combination, then there are 2 solutions.
1. You could use Bolt Cutters to break the Lock open.
2 . Sometimes, the simplest solution is often overlooked, as your lock is a 3 digit combination lock, and if you have about 30 minutes to spare, then why not try all the possible combination from 000 - 999 ( 000, 001, 002, 003 through to 999) You may think this will take a long time, but it should not take you more than 30 minutes and if the first digit of your forgotten code starts with a 0, 1, 2, or 3.. then it will take significantly less than 30 minutes. Try it out, as it will save you from having to buy a new lock if you use bolt cutters.
This is a helpful link that I can give you.
http://shop.heys.ca/help_answer.asp?ID=19
Posted on May 28, 2011
  • 1294 Answers
SOURCE: washer possibly locked
Click on 'washing machines'(below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you hv your manual on line, if available! And dont forget to rate me, on this great site. Possible your belt is off.
Posted on Jan 27, 2008
bhargavchall
  • 6 Answers
SOURCE: how to unlock it with no password
There are basically three ways to unlock the Screen Lock on your iPod:
  1. The most obvious and will not work for most people (or else you wouldn’t be visiting this web site). Simply enter the 4 digit combination/pass code at Extras > Screen Lock.
  2. Connect your iPod to the first computer it was synced with or the computer set as the primary one in iTunes. Open the iTunes application, then disconnect your iPod from the computer, and it should no longer be locked.
  3. Use this final way only if the first two options do not work for you because it is a destructive process.
    Everything on your iPod will be erased.
    This should not be a problem if you have all of your songs, videos, and other media stored in iTunes and you can synchronize once again after getting the iPod unlocked. Besides, if you don’t unlock your iPod it’s useless right? Learn how to Restore your iPod using the instructions from Apple’s site.
If your iPod is simply frozen, follow my instructions for an iPod Lockup Reset.
Posted on Apr 06, 2009
  • 91 Answers
SOURCE: My Samsonite suitecase is open, I forgort my lock
look behind the lock
there is a tiny part (like a stick shift) sticking out of a square about 1 cm across
move it to the diagonally opposite side
reset code
return shift to old position
For those without the little stick shift part, try this: With the case open, and the current combo in place, hold down the shackle (the little grey or black button beside the combination numbers).
While holding this shackle down, rotate the numbers to the number YOU WILL REMEMBER.
(Holding the shackle down allows the numbers to tumble without moving the divots.)
Let go of the shackle -these numbers are now associated with the divots.
Now your combination should be set to the number you wish.
Hope this helps,
Karlos
Posted on Jul 04, 2009
Reset a ZTE ANDROID TRACFONE
Hi. same as most phones go to settings .>> Security > Screen lock. Here you can change the pattern or add a number lock.
Hope this helps
Aug 30, 2017 | ZTE Cell Phones
How open golden antler scope?
Instruction Manuals ' Tasco® - Believe it.
www.tasco.com/pages/instruction-manuals/
Golf Scopes; Infocus - 514FMY ... QP22 Electronic Open Reflex Sight · ProPoint Red Dot Scopes · Tasco Generic Riflescopes (6 Languages) · Vital Zone Reticle ...
bout 236,000 results (0.65 seconds) Search ResultsTasco Golden Antler 3 - (9 x 40 mm) Repair Questions ...www.fixya.com/.../p4821-tasco_golden_antler_3_9_x_40_mm_3_9x40Recent Tasco Golden Antler 3 - (9 x 40 mm) (3-9x40 mm) questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Spotting Scopes.Tasco Scope Problem [Archive] - Cast Boolitscastboolits.gunloads.com > ... > Cast BoolitsAug 1, 2009 - 12 posts - ‎10 authorsErgo, if you have a Tasco or Redfield optic that needs repair, use your ... Have a couple of "golden antler" Tasco scopes a rep gave me back in ...Tasco Golden Antler Riflescope - YouTube
Jan 24, 2016 | Tasco Golden Antler 3 - (9 x 40 mm)...
How to unlock suitcase
Pain in the *** but these are simple three tumbler locks. I am assuming it is what you have. If you start at 000 and go up in increments of 1 you can probably get this in about an hour. Other than that a screwdriver will break it open if you pry in at the locking mechanism.
Dec 01, 2014 | Samsonite Silhouette 11 Hardside Spinner
Forgot suitcase lock code for antler
Unless you want to take it to a locksmith, who can open it in a few seconds, youu can run through all the possible combinations (there are only 1000 of 'em. You may get lucky, and hit a combination that represents something significant to you, such as an anniversary, birthday, or other important number.
Dec 26, 2010 | Locks & Locksmithing
Forget code to antler suitcase combination lock
I am afraid its bad news.
You will need to break in.
Antler will provide a replacement lock at your cost.
Access to the lock is from the inside of your suitcase.
Aug 18, 2010 | Locks & Locksmithing
How to unlock 3 digit lock in samsonite suitecase
mcdevito75 here, You"ll have to find a store that carrys suitcases in your area for help or, you can try to contact Samsonite online at Samsonite.com
Jun 23, 2010 | Samsonite Silhouette 11 HWatch
I forgot my TSA002 lock combination. How to unlock it?
Hi, I watched the videos, but I still can't find a solution to open my luggage (Brand Antler) lock. I remember what is the passcode I set, somehow it just could be opened by using the same passcode.
Please help! thanks
http://nextkl.com
https://sewingasia.com
Apr 27, 2010 | Samsonite Tripod
My Samsonite suitecase is open, I forgort my lock numbers, how can I set up new lock numbers?
reset code
Hope this helps,
Karlos
Jul 04, 2009 | Samsonite Tripod
I cant remeber my sec phone lock...
first try your last four digits of your cell number
Feb 03, 2009 | LG VX9800 Cellular Phone
Locks & Locksmithing Logo
13,411 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
