Question about Husqvarna 450 e-series 18" Chain Saw
Bought 450e in March 2009. Not used it much but doing some maintenance. Having removed the chain tensioner wheel, the chain and bar are loose, but I can't get the clutch cover off: the brake seems to be part of it and the spur sprocket welded on the inside of the clutch/brake won't come out of the machine. If I were to wrench it off, it would damage the brake band which seems to be holding the cover to the outer rim of the clutch/brake. What to do?
spekgt
  • 60 Answers
SOURCE: chain brake band will not release to replace the clutch cover
Hi there
Sometimes that's not an easy job . I work for a Husqvarna dealer and I have that problem frequently . First try to get the clutch cover on place (do not use the bolts) and push in @ the top part of the clutch cover , then try to move the clutch lever backwards to release the band (better if done with two people) . If that does not work the only way is remove the clutch lever with the 2 bolts on each side and put the lever on the clutch cover (top metal piece that looks like a clover)to release the band (again with 2 people one holds the clutch cover and the other one the lever pulling the lever backwards) .
Hope this help
Hope this help
Posted on Sep 03, 2009
  • 4088 Answers
SOURCE: Have husq 445 removed clutch
Use a heavy, wide blade, square-shanked screwdriver to turn the coupling in the cover to 'release'. You may need an open end wrench on the screwdriver shaft to get enough torque to turn the brake coupling. Hope this helps!
Posted on Oct 17, 2010
duane_wong
  • 6826 Answers
SOURCE: On my Husqvarna Rancher 455
I'm not aware of a rim sprocket that will work with the saw.
Posted on Jan 01, 2011
  • 2239 Answers
SOURCE: how do I get the brake band ,located inside the
You need to load the brake, clamp it in a vice, be carefull not to damage the cover, if the hand gaurd is connected to the brake pull it fully back until the locks off, this may take a fair amount of force as it is compressing a large spring, if the hand guard is on the machine, remove it and use this as a tool to load the brake, the only other way is to remoce the clutch and sprocket, now refit the brake onto the saw, now pull the hand guard fully back to load the brake.
Posted on Apr 11, 2011
philwalker78
  • 608 Answers
SOURCE: I remove the chain brake and bar cover from my
Hi, the chain brake has most likely been activated while removing the cover. Place the cover in a vise where the bar nuts tighten up to and pull the chain brake lever backwards towards where the handle bar would be. It should click back and stay back. Hope this helps, regards Phil.
Posted on May 31, 2011
I can't get a replacement chain back on the bar on
The 450E is a tooless system, make sure the brake is off by pulling the handgurd fully back to the top handle, flip up the lever on the big grey fixing nut, undo counter clockwise, wind the grey knurled adjuster wheel facing out of the cover fully back, remove the chainbrake side cover, push the guide bar fully back toward the sprocket, you now have enough rome to replace the chain onto the guide bar rails, now re fit the side cover, make sure the adjuster pawl in the cove aligns with the adjuster hole in the bar, re fit the big fixing nut finger tight, wind the adjuster wheel down to re tention the chain, when the chain is snug all the way around the bar tighten the nut fully.
May 29, 2011 | Husqvarna 450 e-series 18" Chain Saw
How to check for proper chain tension husqvana 450e
You should be able to move the chain with your hands, but not too easily. Please wear gloves when doing this. Also, if you pull the chain away from the bar at the middle of the bar, there should be no more than 1/8" between the bar and chain.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Husqvarna 450 e-series 18" Chain Saw
Chain keeps coming off Poulan 2150 woodsman gas chainsaw> Common causes?
The most likely cause is a loose chain.
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
HTH
Lou
Dec 16, 2009 | Garden
Wild thing chain saw chain came off
The drive links are burred.
512b519.jpg Use a file on the flats of the drive links to remove all burrs.
Then install and properly tension the chain
Chain Adjustment
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Dec 02, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need info on how to change Chain
View the first 1:15 of this:
http://www.youtube.com/watch?v=cdqkIuVNUQc
Install the new chain like this:
Chain Adjustment
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
Lou
Yours is electric there are probably a few differences but the process is very similar.
Nov 12, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
The chain keeps coming off, even after using the wheel to tighten it.
Model and serial numbers would be helpful. You can respond even though the thread is closed below the advertisements.
Remove the clutch cover, bar, and chain. Inspect the drive sprocket is it deeply gouged or perhaps worn through? That can cause this problem. The most likely cause of this problem is incorrect chain installation or a badly burred chain.
The chain will have burrs on the drive links of the chain and may not fit the groove in your bar. If true use a flat file on the side of the drive links and remove all burrs.
Chain adjustment
Your saw is equipped with a "Chain Catcher". That is what causes the burrs. Without the catcher it would have been your leg. Were you wearing chaps? HTH
Lou
Nov 06, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Can not keep chain on bar. Tried 2 different
The inside part of the chain are called drive links. I think when the chains came off the first time (loose chain?) some of these links were slightly deformed (burred). Take a flat file to the burrs on the sides of the drive links. Once repaired keep your chain properly tensioned. Your saw is fitted with a chain catcher (page 9 of your manual), it did its job and kept the chain from smacking your leg (were you wearing chaps?). Burrs are often created when this happens.
Chain adjustment
You can download your "Operator's Manual" and an "IPL" (exploded parts list) here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Lou
If no burrs please repost. This has piqued my interest. I think a brand new chain will operate correctly.
Oct 31, 2009 | Husqvarna Chain Saw 20" Bar
Cannot get new chain on do i have to remove
Put it over the sprocket first, then work your way right putting it into the bar grove as you go, the nose last. Grasp and pull the bar right the chain should rise into grove, you may need to help. Loosen the chain tensioner some put the clutch cover on and tighten the bar nuts finger tight.
Chain adjustment
  2. If necessary, loosen the nuts that are clamping the guide bar in place (or whatever your saw uses to hold the side plate and bar on with). We don't need these really loose - just finger tight will do.
  3. Ease the tension until the chain is obviously loose.
  5. Now, while holding the nose up, adjust the tension so that the chain just touches the underside of the bar.
  6. Continue holding the nose of the bar up & tighten up the side plate nuts / bolts / quick-release system.
Sep 28, 2009 | McCulloch Garden
Chainsaw chain came off/is loose
You need to tighten the chain, and or remove and reinstall the chain depending on whether or not it has come off the drive wheel. The chain drive is on the right hand side of the saw, and there are either two nuts (about 1/2 inch or 13mm) holding the chain on, or there is a little half round handle you can use to tighten the chain after it is on the drive wheel properly. The saws with the two nuts on them have a small flat blade screw on the backside on the bar that you tighten the chain with. And to make things more confusing, some of the newer bars have a round hole in them, that after you loosen the two bolts, you stick a screwdriver in the hole and turn it clockwise to tighten the bar, then you re tighten the 2 nuts.
Since from your description that it wont engage to cut, you will have to remove and reinstall the chain since it is loose from the drive wheel. Clean out all the wood chips, etc in the drive wheel area before you reinstall the chain, make sure it is not on backwards and sharpen and oil it before you use it. Rick
Apr 11, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
I just got a husky 450, not a 450e. im looking for a 20in bar and am havin hell finding one. all i can find is 20 inchers for the 450e.? ?
according to Husquvarna the 450 and the 450e use the same bar.it's just a differant tensing system used. bar number from husquvarna is 508 92 60-80 that's for a 20" bar
Feb 20, 2009 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 450 e-series 18" Chain Saw Logo
89 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
