I have a Sony Rear projection tv, about 7 yrs. The screen is now showing double ghost images in color and curving at the sides. I read advice on "calibrating" using the owners manual (which I lost). Is this something I can do myself? If so can you walk me thru it, without the manual? I appreciate any advice. Adam
  • 6,771 Answers
The picture has gone out of alignment, possible causes are the convergence ic need replacement, or the three picture tubes have become weaker, and in some cases if the unit were moved it can throw out the picture. But from your description it is a convergence issues and will involve two ic's that need replacement along with an alignment set up. I suggest a professional for this job.
Posted on Dec 31, 2010
  • Televison & ... Master
  • 6,694 Answers
u didn't mentioned any thing about u r tv. is it a dlp type one or crt type.if t is crt type then change the crt base of all the three guns. may be ur problem will be solved
ok
Image curve
Image curve, it seems tv got problem with convergence output ICs failure.
Do you get off color picture or like 3 pictures in tv screen?
Is it Sony KP-57HW40 rear projection tv?
Let me know above info to provide you helpful info to solve this issue.
Thanks.
Jan 17, 2011 | Sony KP-57HW40 57" Rear Projection...
Convergence, picture is warped on the sides, double images or ghosts, clear in middle
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Red ghosting on rear projection sony tv year 2002 how to fix
The model number is KP-53HS30, the screen is blurry displayin colors of red green pink
Jun 30, 2008 | Televison & Video
Red shadows and mild distortion
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
Apr 03, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do i get my tv to show the picture straight
THE IS A BOTTON FOR THE ALIGNMENT UNDER THE POWER BUTTON. CLICK ON IT AND SEE IF IT CLEARS. IF THAT DON'T WORK LOG ON TO THE WEBSITE BELOW AND READ ABOUT THE COLOR ADJUSTMENT FOR THE SCREEN VOLTAGES. IF THAT DOESN'T CALL A PREFERRED SONY REPAIR SHOP FOR ADVICE.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Oct 29, 2007 | Sony KP-57WS500 57" Rear Projection...
DOUBLE IMAGES
How do we adjust convergence? I went to the service menu and all I see is alot of settings none of which help me out.
Can anyone explain this in further detail?
TIA
Aug 26, 2007 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
