Question about Cobra 29 LTD CB Radio
No recive an motorboating bad when transmiting
    Problem Solver:
  • 44 Answers
Check ground on radio & antinna
Posted on Jan 03, 2011
No audio transmit or recive
check your final for voltage, work your way from IC 1 on up then check audio transistor . Work your way through the transmit section then the receive section . Check your volume control ,make sure its working alright Just have patience and it might jump right out at you.
Dec 15, 2015 | Cobra 25 WX-NW-ST 40-Channels Base CB...
Uniden PRO510XL low output and "motorboating"
Hi
It sounds like your circuit board may have a bad solder joint. Sometimes during manufacture of the ciruit board, the joint could not be perfectly made. This will limit conduction and create heat which will worsen the effect over time. If you are familiar with opening and working with electronics then I suggest you remove the circuit board and inspect it for cold solder joints. When you find one, you can use a Cigar Torch type lighter to help reflow the solder easily. Out side of that, you mayu want to send it to a Electronics repair shop to do this for you. Let me know more and I will help. Good luck
Jan 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
I have gps 900 peavey the problem is motorboating sounds,can you help me please
Usually, motorboating is caused by a bad capacitor, either in the input section OR in the power amp section (large capacitors) . If you do not know about amplifier repair, you can zap yourself easily if you do not properly discharge capacitors before repair. Do not take a risk of electrocution to save a couple of bucks and possibly do more damage to your unit. Call Peavey for a service center near you.
Dec 20, 2014 | Peavey Audio Players & Recorders
Hi have a cobra model number HH125EU it is stuck on chanle 9will not transmit or recive
It sounds like a synthesiser fault... might require a chip replacement.
Sep 27, 2014 | Radio Communications
I have 2 Motorola TLKR-T3, I haven't used them for a few months but now I replaced the old batteries with new ones and one is not reciving but transmitting, and the other one is transmitting but not...
Try to google or contact maker for
reprograming codes or buttons to hold down
or a web site to download it from an hook them
to computer an load. Sounds like a program
prob
Jun 01, 2014 | Motorola TLKR T5 Two Way Radio
Older cobra 29ltd channel 1-32 all receive channel 20. 33-40 are ok but it transmits on the right channel also motor boats in receive on channels 16-19.
you have a bad channel synthesizer chip on the board i dont know which chip they use,as for the motorboating in the audio,you most likely have a bad electrolytic capacitor in the crossover circuitry before the audio output I.C.( can have 8 or 10 pins on them depending on which chip it uses) mounted on the side panel perpendicular to the board,they run warm,but should never run hot to the touch
Oct 26, 2010 | Cobra 29 LTD CB Radio
My cobra29nwst not transmit not recive but tx its working help me please
Did you try another mic, this one is hard without looking could be a bad soilder or you're voltage regulator could have went out.
Jun 23, 2009 | Radio Communications
I have no reciving in a cobra 29 ltd chrome
Bad switch. It's that simple. The factory switches are crimp together junk. You may be able to use a pair of needle nosed pliers to softly squeeze the case of the switch together to correct the poor contact in side of the switch, but, if it gets a lot of use you may need to replace it altogether. Or try adjusting
Thanks!
Dodgem
http://dodgem250.angelfire.com
Apr 29, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
65 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
