Question about Jacuzzi 9235-959 Nova 6 Whirlpool Bath 6'- White
I have the Jacuzzi 9235 Nova 6 and pump has gone out. Where can I find a replacement pump, and are there options on different pumps to replacement the existing pump?
You can get a replacement motor, or a whole pump at most swimming pool product, or spa outlet stores . Also many plumbing supply houses, or online (http://www.jacuzziwhirlpoolbath-parts.com/) You will need all the info on the motor as well as the pump model. The pumps are usually in a very confined space. It is best to have a professional do the work, however a handy homeowner can make the repair. Just remember this job involves three things water and electricity and in a confined space, so make sure all power to the unit is off even if you are just getting the information needed to replace the pump. As far as options it is best to replace the pump with the same model increasing horsepower or putting a two-speed pump where there was a single-speed may require modifications to the tub.
Posted on Dec 31, 2010
Testimonial: "thanks for the information"
Had turned on the jacuzzi tub and had power failure. Did not turn it off after power came back on. Pump ran without water for 6 hours. How do I test to see if this is now ruined?
Put water in as required, see if the pump leaks out. If not, turn on pump and see if it pumps water. Six hours is a long time, but I would check it before making an assumption that it is damaged.
If it is damaged, you will have to drain the water to repair/replace it.
Gary
Jul 02, 2011 | Jacuzzi DX50-959 Elara 7242 Salon Spa...
Pump motor leaking at connections
take the pump unions off the motor and look inside them at the tailpiece. You should see one black rubber o-ring inside each one. Make sure they are seated properly in the grove on the tailpiece and reinstall.
If they appear to be flattened on one side you may want to get some new # 0-49 o-rings and change them.
Once they are seated properly your pump unions will no longer leak water.
Feb 12, 2011 | Jacuzzi 6800-959 Nova 6 Whirlpool Bath 6'-...
Motor work but jets do not operate
You can hear the pump come on but get no water through the jets?Is the motor running or is it just humming
Feb 10, 2011 | Jacuzzi 9235-959 Nova 6 Whirlpool Bath 6'-...
How to separate the two impeller flanges of a jacuzzi pump to access the impeller in order to remove the wet end from the motor OR is there some way to remove the wet end of a white JWB 60C Ser no. 06785...
That is an old sealed Jacuzzi pump that can not be repaired. It is one of many reasons why Jacuzzi never did well in the pump business and has gone from owner to owner over the years. Unfortunately your pump is not repairable without destroying it in the process.
Wet ends may still be available. The part numbers I have are:
850100 .5/.75 HP
9011000 1 HP
850200 1.5 HP
856600 2 HP
0199000 Gasket (2 req’d)
4516000 Flange, 2”
Good luck,
John
Aug 22, 2010 | Jacuzzi Impeller, L - 3/4 H.P
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
My jacuzzi pool pump cracked so I need to replace it. Jacuzzi is no longer making parts, so what would be a good brand where I could still use the same pipes, filter, etc.?
here's a site where I found tons of jacuzzi parts and accessories.
http://calwesthot1.reachlocal.net/AdvancedSearch.aspx
under select catagory scroll about half way down to jacuzzi pumps and hit search.
If you find what you need can I borrow the jacuzzi .. lol
Jul 31, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Jacuzzi nova 532 motor run's but won't stay running
If it has the little oval off/on button, it sounds like the control box or off/on button is bad. If you have access to the pump assembly, follow the pump power cord to the little black box (zip tied to a tube up high), this black box has a small cable that goes to the off/on button. unplug the pump from the box and plug the pump into the power outlet. it should run continuously. If it runs, you need a new control box or /offon button. Buy the off/on button first, as this button is prone to water getting into it, and costs less than the control box.
Mar 25, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi 9235-959 Nova 6 Whirlpool Bath 6'- White Logo
147 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
