Question about Toshiba Computers & Internet
Broken power adaptor plug - Toshiba Computers & Internet
    Genius:
  • Toshiba Master
  • 1,274 Answers
If you're any good at soldering then this isn't too big of a deal, you can buy a plug on ebay pretty cheap however most come from china. (I assume you're talking about the pc end) you'll have to completely disassemble the laptop desolder the old connections and solder in the new one. then put it all back together and test it. if you're afraid to do this, some pc shops will do it, but it's not cheap because it requires alot of work to disassemble a laptop. in todays market and given that it's a toshiba it may be cheaper to to purchase a new laptop, and move the data from the old to the new. you can get a laptop for fairly cheap these days on ebay or other sites. good luck :)
Posted on Dec 31, 2010
I havo a magic jack plus. The power adaptor broken
All MagicJack Power Adapters provide 5v DC through USB interface. Until replacement can be obtained, you can plug MagicJack into your computer USB port (computer must stay on to provide power however)
Sep 04, 2014 | Computers & Internet
I have a lw1210er and I do not have a light on the power cord? Any suggestions?
Test the plug cable in another charge adaptor if the light comes on your adaptor is broken
Jul 23, 2014 | Computers & Internet
HP Desktop Modem broken ethernet port
Try to load the latest driver, you can get that from HP under your computer. If that does not fix it then go buy a cheap USB Ethernet adaptor from Amazon or BestBuy, plug it in to a spare USB port and follow the directions for the adaptor with your Ethernet cable plugged into the new adaptor.
That is it, you have bypassed the bad Ethernet power and can forget about it (they can't be fixed), you should be good to go.
If you don't want to try the driver, then just get a new adaptor and that will bypass the internal adaptor.
Good Luck
Mar 15, 2014 | HP Computers & Internet
I have a Yamaha PSRE413. on/off does not work with adaptor, but works with batteries
If you are using the correct adaptor then the most likely reason is that the socket where the adaptor plugs in has broken away from the circuit board and will need to replaced/resoldered.
if you need a socket Google : Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
OR if you have used the wrong mains adaptor and the polarity was reversed you may have damaged the diodes / voltage regulator on the power input.
Jan 24, 2013 | Yamaha Music
On my SNES console where I plug in the AC adaptor it slips out a little (and I have the right model AC adaptor) and there are two pins sticking out from the consoles connector. I have a new adaptor and AV...
Well it might be broken for that part you say thats busted so you could sell your as broken and maybe some nerd might buy it from you guys then. Buy a new SNES console.
Jun 13, 2011 | Nintendo Super NES Console
How do I switch to normal power when the battery is running out please. It is a Medion Laptop. The battery warning light flashes and then the laptop warns 'switch to power' but I can't find out how to. It...
This might be an indication of a problem related to either the power adapter, the power cord, or the power receptacle in the laptop.
Please refer to the following article for detailed diagnosis & a fix:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Dec 21, 2010 | Computers & Internet
No power but works through usb
Checkthe 9volt dc adaptor with a volt meter to make sure it is supplying the unit with power. Does the power indicator light come on when you plug it into the wall? if the power adaptor is supplying power, then next i would check for an internal OR external fuse around where the power plugs in, also making sure the plug it plugs into is not loose or wiggling as this could mean the female portion of the plug may have bad soldering or has been broken. please post again here with your findings... Regards
Jun 21, 2010 | Edirol SD20 Studio Canvas USB/Serial/MIDI...
Power adaptor is broken
You can buy power adapters from Amazon.com. You might want to buy a surge protector and plug it into that. Most likely you live in an apartment or older house where the power damaged your power adaptor. Get a good surge protector to plug in all your devices to.
Here is the link to buy from Amazon.
http://www.amazon.com/Aftermarket-replacement-AV3500T6001-AV3500T8001-AV6200H6001/dp/B0029V4KYU/ref=sr_1_7?ie=UTF8&s=electronics&qid=1255196406&sr=8-7
Oct 10, 2009 | Averatec 3200 Notebook
BROKEN adapter PLUG IN ON SUPER NINTENDO
The dc jack where you plug in the ac adaptor is worn out which is why it is chipping and also why you can't make a good enough connection for the ac adaptor so you can turn on the Super Nintendo.
What needs to happen is your SNES needs to have the old dc jack taken off and a new one soldered on.
If you can find another broken SNES that has a good working dc jack then take if off of that one and solder it onto yours and your SNES will work like new.
May 28, 2009 | Nintendo Super NES Console
ACER ASPIRE LAPTOP 2920 NO DISPLAY
Ckeck if your adaptor has power on the connector to laptop.
Might be damaged power cord (to and from the adaptor) or broken adaptor.
While there was power in the battery, it was running, but not charging.
Now the battery is emty and can't be charged because of broken adaptor/cables.
If you find there is no power from the adaptor, bepair it or buy a new one.
Do not try to repair the adaptor by yourself if you are not a technician, it is DANGEROUS !
Either give it to a qualified servicer, or betteer, buy a new one.
Regards.
Mar 27, 2009 | Computers & Internet
Computers & Internet Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
