From time to time some buttons on the remote control for my sagem freesat plus refuse to work, especially the record button and pause. If I turn off the power to the box then on again the problem is resolved but this is a nuisance. Thank you, Susan Bastable
  • Televison & ... Master
  • 6,694 Answers
u have to clean the remote. for that u have to open the remote. watch the following video. if there is no screw do steps after that.
ok
From time to time some - utube.png You-Tube video "DBBJlGFUWv0" placeholder (do not delete) utube.png
Posted on Dec 31, 2010
FREESAT SAGEM REMOTE CODES
028,011,073,083,091,000 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 02, 2013 | Televison & Video
Dish Network controller doesn't work if you happen to pause or stop when the screen is black or on a dark picture. You have to turn TV and control box off then back on to regain controller.
falcondan
The remote works fine other than this stated problem? What type receiver and TV do you have? Do this just began occurring? Have you checked the batteries to make sure they are fresh? Is this on TV 1 or TV 2? One thing you may try is readdressing the remote to the receiver.
Remote: All Other Remotes
  1. Go to System Info screen (press Menu button 2 times on remote).
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Jun 25, 2011 | DISH Network IR Remote Control
How to program a crimestopper remote control model #chx433tx
To program this remote-
1) Open hood or ground GREY wire @ pin #7 on 12 pin connector coming from Crimestopper control module usually located under dash.
2) Turn key to on position.
3) Press red programming button coming from module 4 times, after a few seconds the parking lights on vehicle should flash 4 times.
4) Press button #1 pause, #2 pause, #3 pause, #4 pause on the remote you are programming, the lights should flash after ever button push. After all four codes (buttons) are learned, the unit will exit code learning mode. If not, turn off key and close hood. Hope this helps......BUZZ
Mar 07, 2011 | 4-Button Remote Start/Keyless Entry with...
Remote control buttons won't work
you may have a fualty remote you may want to bring it back theres nothing you can really do
Oct 08, 2009 | Logitech Pure-Fi Express Plus...
New codes for Nikkai big button remote control
hi...if don't mind can you send me a Picture and model you're universal remote what kind a universal remote you have.?i need to see what is that likely remote then i teach you to how its work done..Thanks
Apr 23, 2009 | Televison & Video
Trouble switching on my Sagem 6200T PVR.
Hi margaretanne on Dec 02, 2008
I have a similar problem with mine. I find the battteries are loose, I remove the back of the remote, jiggle the batteries and press the button, and it works, until I drop the remote and the batteries loosen again.
Dec 02, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Can get to region unlock menu but refuses to change.
hi try this one there are 2 versions they both have different chips.
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
it worked for me.
Sep 24, 2007 | Cyberhome DVR 1600 DVD Recorder
Quasar camcorder model# vm-d52
your pause . . . button . . . has come loose from the tiny switch that actually controls pause ; the remote ( it has a battery ) can activate pause , directly from your control chip and is cheaper than the repair ;
Jul 28, 2007 | Quasar VM-D52 Camcorder
How to reset recorder
The solution to hold the pause button for 5 seconds is a winner. Just make sure you press the DVD button first. This doesn't work in VCR mode. This button is on the actual unit, NOT the remote. Thanks for this help.
Apr 18, 2007 | Sony RDR-VX500 DVD Recorder/VCR
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
