Question about Microwave Ovens
MAYTAG MGR5745ADW GAS RANGE...Was using oven and heard a popping noise and a flash. Oven shutoff, no display and none of the oven, timer, clock controls work. Burners still ignite o.k.
  • Barrett Palumbo
    Barrett Palumbo Dec 31, 2010
    Sorry to read about your issues.
    But you really need to give us the make and model, of your unit. It kinda helps us to help you. and a more detailed explanation, of whats is going on.. gas oven or microwave
5 Suggested Answers
SOURCE: Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Posted on Sep 24, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: We have a brand new
E63 is a "T1 Max Time" error. It indicates a problem on the control board.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Keep a close eye on it, and if it fails again, you want to contact Maytag for free warranty repair.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 27, 2008
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Posted on Aug 14, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Range RF315PXDW
It sounds like you are missing part of your input voltage.
I would take a voltage reading at the receptacle and confirm you are reading 220-240VAC. Some homes have the 220 service receptacles wired up with two 120 volt breakers to make up your 220 service. If your home is configured this way, you may have one of the breakers tripped. Or, the receptacle itself may be bad. If you confirm you have the correct voltage at the receptacle, your power cord may be bad.
The reason the clock and display will still appear to work is because the clock only uses 110-120VAC and is tapped off the source voltage. The surface burners and the oven heating elements, however, require the full 220 service.
If you are confused by this explanation, please post back and let me know. Hopefully, this is a problem that will not require any parts or a service call. If the power cord is bad, you can purchase a replacement at any hardware store. I hope this information is helpful.
Posted on Dec 19, 2009
Testimonial: "I will definitely check both the 120v wires in receptacle feeding power to the stove. The breaker in the house breaker box is a single 60amp breaker. "
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
Maytag microwave cook delay - first minute on timer no heating, then works fine
Not a feature I've heard of.
I would do a hard reset by unplugging the oven for a minute or two, setting the clock, then trying again.
If it still does this, I would contact Maytag customer service at the number in the owner's manual.
Dec 25, 2012 | Maytag MMV6180WS Over the Range Microwaves
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
I heard a pop and now the micro is not heating but everything else works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101.,/,/
May 21, 2010 | Maytag MMV5207AAS Microwave Oven
MMV5207AAS stainless_steel 1100 Watts Microwave Oven: I heard a pop and now the micro is not heating but...
Microwave Oven Basic Troubleshooting Tips
heatman101
gdhj
May 18, 2010 | Maytag MMV5207AAS Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
