I turn the button to spin and after the mechine stop i can't even open the door,how can i do??
  • 784 Answers
You can try and unplug the unit from the wall and see if that will disengage the locking mechanism.
c...
Posted on Dec 31, 2010
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
How do I open washing machine door
check mains going into mechine
Feb 27, 2015 | Miele Washing Machines
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
My arm won't lower onto record, the arm lowewring mechinism won't lower
After my THIRD Ion turntable had the arm-lowering problem...
I rotated the platter counterclockwise about 12 times and it worked...for now. I'll keep my fingers crossed and hope it wasn't a fluke.
Dec 29, 2011 | ION Audio iTTUSB Turntable
When I accidently push the start button when I mean to push the key button to open the door, the cycle will start again. Is there any way to stop it?
Push and hold down the start button again. The machine will stop. Turn to Spin (to drain the water that burped into the machine when you turned it on by accident). Hit start, let the drain and spin cycle complete. Hit the key button and you're all set.
Sep 24, 2011 | Asko W6021 Front Load Washer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
Jan 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
On a 2004 cavalier, my rear driver side door wont open from the inside or out. i removed the door panels, compared the two to find the mechinism that opens the door is broken or jamed. i tryed everything...
Unbolt the hinges at the other end of the door and unbolt the pin that the the door latch locks on. The pin nut is behind the seat back. Be careful that the door doesn't fall on the floor and get scratched up. Good Luck
Mar 20, 2010 | 2004 Chevrolet Cavalier
The DVD will not stop spinning. The door will not open either. When I took the cover of the players and plugged it in, the DVD just keeps spinning even when I hit STOP, OPEN, and turn the player OFF. ...
I've had this problem twice now.
The first time, I unplugged the unit for about a minute, plugged it back in and pressed the Open button. The disc was ejected and ran fine for about a week.
Then it happened again, but the unplugging didn't fix it this time.
Try this;
Unplug the unit and let it sit for a few mins to let the disc stop spinning. Then gently pull down on the DVD door. Look at the lower left side of the DVD tray and you should see a large slot. Shine a light into the slot and you will see a dime size white gear. I used a small flat head screwdriver to spin the gear to the right. After 2 small turns, the DVD tray opened enough so that I could pull it gently open. I took the DVD out, gently pushed the DVD tray back in and set the DVD player on my workbench to tinker with on a rainy day. Not sure what the root cause is, but I'll worry about that later!
Aug 14, 2009 | Samsung DVD-R135
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
