Question about Zanussi Washing Machines
I have a zanussi turbodry WDT1085 and wish to reaplce the bearing. Are there any service manuals available so I dont mess up replacing it? The user manuals are useless.
kjmac
  • 97 Answers
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
gittos73
  • 244 Answers
SOURCE: zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Posted on Nov 25, 2008
  • 17 Answers
SOURCE: What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: removing/replacing main drum bearing on a zanussi WDT1085
Yes you do need to remove the drum, it entails stripping the washer down, and it is normal practice to replace the complete drum half with the bearings pre-fitted..
It is not a job to undertake, unless you feel competent to do do it, as it entails al ot of work and time..
Good luck if you decide to proceed.
Plz rate my suggestions.
.Thanks.
Posted on Jan 03, 2009
  • 57 Answers
SOURCE: zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Posted on Jun 24, 2009
My washing machine is zanussi turbodry 1200.Is there an instruction manual I can download?
You should be able to get one from zanussi by going on to there website
Dec 15, 2017 | Zanussi Washing Machines
I need manuals for zanussi turbodry zww 1202
Go to
http://www.manualslib.com
Then type in the manual you need..
Hope this helps
Ellen
Feb 04, 2015 | Zanussi Washing Machines
Where can I find a manual?
You may view/download the manual here.
Mar 14, 2012 | Zanussi Washing Machines
Zanussi jetsystem turbodry 1200 door wont open
Jun 24, 2009 | Zanussi ZWF1420W Front Load Washer
Removing/replacing main drum bearing on a zanussi WDT1085
.Thanks.
Jan 03, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Washer stuck
i am assuming that water comes in at the start of cycle and machine does not then progress. Points to a timer fault unfortunately. These timers are expensive and quite hard to fit. don't recommend repair in view of age of appliance.
honestly can't see how related to sock problem
Jun 26, 2008 | Washing Machines
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
81 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
