My Rayburn 480K makes the clicking noise I associate with the boiler igniting whilst it is already running. It continues to click until it finally trips out.Can you help?
4 Suggested Answers
SOURCE: Hi we have a rayburn
hello there. I have the same problem. Did you ever solve your problem with the Rayburn tripping out the sockets?
Posted on Mar 05, 2011
  • 4736 Answers
SOURCE: We have just bought a
This can be caused by several things. Incorrect Gas to Air mixture in the burner air intake valve. . Debris in the gas line to the boiler. To high a gas pressure. Depending on whether you installed this unit or not, will determine if you should try to repair or troubleshoot these issues. If it was professionally installed call the company that installed it. The only one you can't troubleshoot is the gas pressure. That needs to be done by a certified gas technician.
Hope this helps steer you in the right direction to solving the problem.
Posted on Mar 15, 2011
marcus_lasan
  • 4 Answers
Just something to try: On the control board you will find a connector block for your central heating pump. Its your normal brown and blue wire ples yellow green earth and is clearly marked 'pump' Disconnect it and see if it solves the problem? If it does you may need to replace the central heating pump. When I ought mine the movers just cut the wire and it shorted.
Posted on Dec 03, 2012
Rayburn 480k heating control lockouts why? not always able to reset and no obvious reason help
Failed switches or plugs. Need to look at plugs or switches /relays. Check voltage and amperage.
Oct 16, 2016 | Cars & Trucks
Boiler lights and runs Ok when first switched on, when it goes to reignite, it just keeps clicking (sparking) Pilot lights but boiler will not fire up.
This isn't very helpful at present.
What's the make and model of boiler?
Do you mean after the first (successful) ignition subsequent ignition attempts fail?
What happens if you turn the electrical power to the boiler OFF, then back ON ?
Feb 07, 2013 | Baby Gear
Potterton performa 28 flame failure
Chech ignitor is clean and the flame sencer , also check presseure switch see it this is working try jumping it out , and check fan is working , check water leval in boiler if its a combi.
Jul 14, 2012 | Heating & Cooling
Rayburn 480 ag, pilot goes out
rayburn nouvelle thermocouple keeps burning out any suggestions
Dec 25, 2009 | Kitchen Ranges
Rayburn reliability
YOU WILL FIND THAT YOU HAVE A CRACK IN THE OVEN. THIS LETS IN MORE AIR THEN THE BURNER NEEDS SO MAKING THE BURN VERY HOT. YOU NEED TO FIX THE CRACK.THE BURNER NEEDS TO RETURN A READING OF 11-11.5 CO2 AJUST AIR TO MAKE IT THAT THE LOOK AT O2 IF IT IS HIGHER THAN 6.5ITS CRACKED IF ITS A MARK1 OR MARK 2 YOU WILL NEED TO CALL ME AS RAYBURN NO LONGER MAKE THAT PART AND I DO IF ITS AN MX OR MXE THE PART CAN BE GOT. info@topoftherangeltd.co.uk
Oct 02, 2009 | Kitchen Ranges
Gas range igniters won't shut off
The problem that you're describing is commonly associated with the spark modulator. It usually occurs after a spill or when the ignitor electrodes have remained wet after a cleaning. If after a day or two it continues to spark intermittently on its own, then the only recourse would be to replace the module. Hope this helps,,,, Bill
May 28, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
1994 lincoln wont start and does clicking noises
do you know ware the clicking noise is comming from? maybe relay? maybe bad sellinoid? the sellinoid is my guess.
Jan 02, 2009 | 1994 Lincoln Continental
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
