Question about HP Computers & Internet
My HP laptop suddenly stopped working - mid use - a few days before Christmas. Despite disconnecting / reconnecting the power cable and trying to turn it back on in both modes, all that flashes (briefly) is the middle of 3 light indicators on the bottom left of the laptop (looks like the 'power' indicator light). Have absolutely no idea what has happened and would value some advice (preferably in non-tech speak!) as I need this machine for work next week. Thanks in anticipation, Eileen.
    Genius:
  • 1,288 Answers
You have a couple of options here:
Remove the battery and the AC adaptor, press the power buttin in and hold for 30 seconds, release, reconnect the battery and AC power adaptor and try again. If this does not work, check the output voltage on the jack that goes into the laptop from the adaptor with a multimeter (If you are not technically minded, ask someone to do this for you). Set the DV volt scale of the meter to 20 volts and connect one probe to the inside of the jack and one to the outside, if you do not get a reading, the AC adaptor has failed. If you do, you can eliminate this as a problem and assume that the power is getting to the laptop.
Check the tightness of the jack connection to the laptop, if it feels "sloppy" the port is on its way out and will need replacing before arcing damages the charger board.
I do feel however, that.. and I'm going to stick my neck out and say this is a DV or G series laptop, that the motherboard is damaged. Usually the display goes first then the rest of the laptop. This is due to a very bad cooling system on the laptop and complicated by a build up of dust and fluff in the cooling components all of which kill the chip.
If this is the case, then any repair will probebly be expensive
Posted on Dec 31, 2010
    Genius:
  • HP Master
  • 1,274 Answers
When this happened was your laptop hot to the touch on the underside? it's possible it may have overheated and ate itself, pull the battery off for about 60 seconds, and reinstall. then try again.
Stopped printing and will not continue.... the middle orange light stays on
Press the "Power" button to turn off the printer. Wait a few seconds and then power it back on.
Power off the printer again if you are still running into problems and disconnect the power cable from the AC power. Wait a few seconds and reconnect the power cable. Power on the printer. This simple procedure resets the printer back to the default factory settings. Move to the next step if the reset does not work. Select "Setup" on the CD and select "Remove HP Desk Jet 932c. The printer software and drivers are removed from your computer. Reconnect the USB Cable to the printer. The installation disc automatically recognizes it and begins reinstalling the software and drivers.
Here is the link if you cannot find your installation disk:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=25305&taskId=135
Print a test sheet to verify that the printer is now working. You can print a test sheet using a word processing application.
Mar 03, 2011 | HP DeskJet 932c InkJet Printer
HP invent screen with scrolling bar continues forever and printer never powers up beyond this.
Please try disconnecting the power cable for a few minutes. Then, reconnect the power cable and try turning it on.
Mar 02, 2011 | HP PSC 2355 All-In-One InkJet Printer
My xbox is giving me 3 red rings which should mean that there is a connection or hook up problem ive gotten it to work after this once but there were no connection problems then after not playing it for a...
Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
  2. Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  3. Make sure that all three connections are firmly secured.
  4. Turn your console back on.
  5. Check the light on the power supply. If this solution worked, your power supply light will be green....
Dec 23, 2010 | Microsoft Xbox 360 Console
My computer says there is a paper jam but there is none on the display screen. I tried opening it up but it doesn't work, my computer still says it has a paper jam. My printer is HP Officejet 4355. My...
Turn the printer off.
Disconnect the AC power.
Disconnect the "data" cable from the computer.
Reconnect the AC power.
Turn the printer on.
Press the "paper-feed" button, to try to feed a few sheets of paper through the paper.
Reconnect the "data" cable.
If this fails, take the printer to a qualified technician, for professional trouble-shooting.
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
My HP Deskjet F380 has the latest printing software installed; it spools and is attached to my laptop in the correct USB port; but it doesn't print. The message is "no connection." It printed...
Verify that the USB connection is fully inserted in the back of the printer itself. If all is well there, try to think if you've run any updates on your laptop recently, or installed any new software that could be conflicting. If yes, try removing the new software or recent updates, and try a test print. If this still does not work, try disconnecting the printer, powering down your machine, starting it back up and then reconnecting the printer to the USB port. Sometimes you have have a glitch in the USB port that causes your computer to stop recognizing a device seemingly out of nowhere. If none of the above seems to help, it might be as simple as a USB cable that's become faulty. Hope this helps!
Nov 19, 2010 | HP DeskJet F380 All-In-One Printer
Continues to say the "check your color cartridge" despite new cartridge and double checked reinsertion.
Please rest your Machine... to do this follow the instructions below;
First of all, Remove the cartridges, and clean the contact points on the cartridges and on the printer.
  • - Turn off your printer, disconnect usb cable, power chord etc.. open the back door, press the power button several times.....
  • - Now connect the power chord and power the machine while you keep pressing the power button (don't hold down), and let me boot up, leave it On for few minutes.
  • - Turn it Off and install the cartridges, reconnect the usb cable, etc.. and reboot the machine. You'll see how it works. If you have problem even after this, please let me know.
Good luck.
Thanks for using FixYa.
Jun 15, 2010 | HP PSC 950 All-In-One InkJet Printer
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
Wii won't turn on
if there is no lights going on at all while the power is plugged in and you pressed the power button.
it is pretty safe to assume that either the power unit or the wii is not working anymore.
but if you bought it last christmas you should still have warrentee and nintende should be able to fix this.
Jan 27, 2009 | Nintendo Wii Console
Carriage jammed
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Oct 27, 2008 | HP ScanJet 4500C Flatbed Scanner
Notebook cannot power on
get multiple advice from different technicians... changing motherboard in a laptop is not cost effective. check your warranty and send it back to manufacturer.
do this first... disconnect all power source --take out the battery from your laptop, disconnect the power cable... leave it for 5 minutes or longer and reconnect the power source and turn on the laptop. "if this works, don't go back to that technician that says change the motherboard"
if this doesn't work and and you get the same recommendation to change the motherboard from other technician... it is more cost effective to get a new laptop. if you replace the motherboard, you will have to pay the shipping, service and the parts = new laptop (new warranty)
Jun 03, 2008 | Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
