Question about Fuji Finepix S9600 Digital Camera
It has been sent back to Fuji who say it's fine have put durcell in it and left it to charge but with no batteries in put batteries in it left it and turned it on after 1 hr and 30 mins and it still wopn't work!!??? please help FUJI S9600
  • 747 Answers
At this point you can only trust Fuji that they are correct in what they are saying in that the camera is fine which leaves only the power source you are using. I'm a bit confused as to what you have written. You said you put Duracell in it and left it to charge. To my knowledge and I may be reading this incorrectly it appears to me you are installing batteries in the camera and possibly hooking up the USB download cable expecting the camera to charge the batteries. The camera has no charging capabilities and rechargeable batteries need to be charged in a separate device made specifically for this function. I also know that some chargers come with a clear plastic guard over the + (positive) terminals and if you do not remove this plastic part there is no way the batteries can be charges. The charging lights come on and will remain on but no charge will enter the batteries. Maybe a quick test would be if you have a flashlight that takes AA batteries you place them in there and turn the flashlight on. Once you have confirmed that there is battery power then insert the batteries into the camera make sure they are in the correct placement (orientation)
Here is a picture of the correct battery placement.
This diagram is found on page 13 of your owners manual
Another diagram I'm including is what the camera will show as the battery state of charge.
This is found on page 15
I sincerely hope this helps
Posted on Dec 31, 2010
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
I sent my Fuji S3 pro off to be cleaned and serviced in Miami and to repair the mini USB port which had came loose. After I received it back, all worked well, but I noticed that it eats batteries like...
Digital cameras are famously demanding on batteries, and the early Fuji ones were notorious. You must use good alkaline batteries or better, a set of high capacity NiMH rechargeables. Zinc or "long life" batteries just aren't up to the task, and they can leak and cause corrosion.
NiMH batteries with a capacity of 2700mAH are available, and these will last longer, per charge, than name brand alkalines, as well as being rechargeable. You can buy these with a charger fairly cheaply now (though they obviously cost more than disposables). You will probably want two sets, one to be on charge while you use the other.
Nov 03, 2010 | Fuji FinePix S3 Pro Digital Camera
I Have a Fujifilm Finepix J37 that wont turn on, I assumed that the battery had run down so put it on charge and no lights came on, usually it lights up on the back of the camera when its charging! Faulty...
hmm i have the same problem with mine.i got a replacement battery and it worked fine for a few days but then went back to the way it was. so i'm thinking the problem is with the camera itself. how long have you had the camera for?
Sep 08, 2010 | Fuji Cameras
My fuji digital camera will not charge when I put it on the charging base.
Usually that just means your battery needs repplacement. Get a new one put it on the charger overnight and the camera should be back to normal.
Mar 26, 2010 | Fuji FinePix A330 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Fuji FinePix F700 LCD & Zoon Lens
Is the battery fully charged? Or is the battery near the end of its useful life? Some batteries hold a charge better than others-- I have 2, both used well, and one seems to last longer than the other...
Aug 25, 2008 | Fuji FinePix F700 Digital Camera
Fuji FinePix S500
try using it with fresh pair of fully charged batteries.
Jul 24, 2008 | Fuji FinePix S5000 Digital Camera
Black screen
This is a CCD sensor ( see pic below from Canon camera with same pixalage and specs ) problem : outputting too much noise or nothing at all so the sensor must be replaced ( not a big job but ha sto be done by someone with experience and the right parts ). Fuji will repair free of charge , if I am not mistaken, so you need to contact your Fuji agent .b16210b.jpg
Nov 25, 2007 | Fuji FinePix Z1 Digital Camera
It Isn't Working
I just today sent my camera to Fuji to have the same thing repaired. I've read that the on-off switch tends to fail on this camera.Mine is just a few months past warranty, of course!
this is my 3rd Fuji and 1st problem though.
Good Luck.
Nov 11, 2007 | Fuji FinePix S9000 Zoom Digital Camera
Camera that won't take pictures
Are the batteries FULLY charged?
This has happened to me!
Mar 13, 2007 | Fuji FinePix A600 Digital Camera
Fuji Finepix S9600 Digital Camera Logo
74 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
