FixYa.com
Tags:
Intel 845GE Motherboard
No display
posted by ucp_pru on Jul 08, 2008
fan is moving,memory is ok.cpu seats correctly,still no display
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 08, 2008
Not Rated (0)
sanane
Rank:Apprentice Apprentice
Rating: 78%, 2 votes
-Check memory first, (no memory no display, but it should beep)
-Check CPU, means no brain (cannot do much)
-Finally try another power supply (must supply correct voltage on all rails) of course the mainboard must be good too.
Hope it helps..
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
eng_darwish1
Rank:Wiz Wiz
Rating: 79%, 30 votes
try to connect external vga card
on agp prot or pci. if nothing show up then it might be bios chip. try to replace it from similar mother
Can you Help with these Motherboards problems?
Motherboards
manual needed for Hp 383620-001...
i need a manual for Hp system... Answer This...
Motherboards
carte mere adequat ? mon...
j'ai boitier du mdele... Answer This...
Motherboards
My camera is not working,
My LG KU990 camera is not... Answer This...
driver not founding
please help me to download my... Answer This...
vrm circuit fail IC ADP3168...
what should i do Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
