Question about Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor
I need a manual for a clarke bronco 6 gal compressor (ac20008). When I use the unit, I am cutting the circuit breaker off.
  • 784 Answers
I would try a different outlet ( which should be on a different breaker ) -- sounds like your breaker is either bad or to low of a amp rating to handle the load of the compressor.
c...
Posted on Dec 31, 2010
  • lhscarclub Dec 31, 2010
    Thanks but already tried this.
I have a Craftsman (919.176820) 2HP, 12 gal. compressor. I starts fine the first time, it reaches full pressure and cuts off. When the pressure drops and it tries to start again, the motor lugs and trips...
Your tank check valve is stuck/broke. It's on the tank end of the line from the pump to the tank. It is supposed to close when the pump stops to keep air in the tank and let the system bleed pressure out of the pump so the motor can start when there is pressure in the tank. The part you need is CAC-437-2 and is available through searspartsdirect.com.
Feb 22, 2012 | Craftsman 33 gal Air Compressor 6 hp...
Compressor runs but the air bleeds out think it might be stuck reed
If your compressor reaches the cut-out pressure (or very close) , most likely not reed valves. Usually air leaking when compressor is shut off is result of leaking check valve at the tank. Look for brass valve and remove. Somtimes the valve is repairable if debris is keeping valve open. Clean or replace as needed.
Oct 21, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Problem with the craftsman 30 gal compressor 6 hp vertical oil free. motor or compressor will not engage, when turned motor starts for a second and sound slow then pops the breaker
sounds like you are not getting enough voltage to run the compressor if you are using an extension cord check your manual to see what gauge it should be depending on how long it is if you are plugged into a wall outlet then is the compressor the only thing that is running on the circuit if some thing else is running then you may be overloading the circuit.
Feb 24, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I have a C2150 4 gal compressor from Porter cable with 2hp peak and 1.2hp continous rated motor. The problem is that I can not run the compressor on a 15amp circuit with out tripping the breaker. It even...
Try to use a higher amperage extension cord.
This unit is rated for 15 amps. It should be able to run on a 20 amp circuit unless there is voltage drop due to small wiring. Try an air conditioner extension and let us know the result.
Gary
Dec 19, 2010 | Porter Cable C2002 150 Psi 6 Gal...
I own i 20 gal. clarke abrasive blaster. My problem is that i can only blast for about 30 seconds and then have to wait almost 2 minutes for the pressure to build back up
Sounds like your compressor doesn't have the cfm to keep up with the blaster. Blasters use a lot of air. The cfm of your compressor should match or exceed the cfm of the baster. Try a bigger compressor.
Good Luck!
Aug 20, 2009 | Clarke Power Products Clarke 10 Gal....
Husky m1506f Air compressor will not turn on
Look for a reset circuit breaker button on or near the compressor motor. It might be black in color.
Jun 19, 2009 | Air Tools & Compressors
Breaker relay tripping out
If the unloading valve trips , which i think is the safety valve that tells me the compressor is pumping up past its maximum allowed pressure. that black switch should be the overload switch. check the amps of the wires going to the motor while its running and then look at the name plate of the motor to see the maximum amount of amps that the motor is allowed to draw.
Mar 31, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
203 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
