Question about Toys
Procedure to disassembale rear wheel assembly to gain access to gearbox
    Problem Solver:
  • 4 Answers
Db dgzd
Posted on Dec 31, 2010
How to remove back seat of hhr 2006
Rear Seat Replacement
showgif.do?image=1592810
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Preliminary Procedure Remove the rear compartment floor stowage compartment tray. Refer to Rear Floor Trim Plate Replacement .
Nut, Rear Seat (Qty: 6)
Tip
Roll the seat forward enough to get access to the nut that attaches the center seat belt assembly to the floor.
Tighten
45 N?·m (33 lb ft)
Bolt, Rear Seat (Qty: 3)
Tip
  1. Adjust the seat forward or rearward to access the bolts.
  2. Remove the plastic trim pieces to gain access to the nuts.
Tighten
45 N?·m (33 lb ft)
Rear Seat Assembly
Oct 28, 2015 | Seat Cars & Trucks
How to remove motor from john deere gator power wheels
1. Remove the center caps from the rear wheels
2. use a 13mm wrench on each side and loosen the bolts
3. remove the rear wheels and axle
4. remove the red pin at the front of the dump bed
5. remove the two black pins at the rear of the dump bed
6. remove the dump bed
7. lift the green plastic cover off
8. remove the two screws that hold the gearbox and motor to the body
9. remove the gearbox and motor assembly
10. remove the two screws that hold the motor to the gearbox
May 19, 2014 | Peg Perego John Deere Gator HPX Ride on...
Leaking oil between the gear box and engine
Leaking rear main seal.
Remove the gearbox and clutch, inspect clutch, pressure plate and throw out bearing for wear and replace if necessary, remove flywheel.
Now that you've gained access to the rear main seal, remove it carefully with a hook or screwdriver, some are bolted in (don't score chip or mark the crank) inspect the crank for a wear grove. If a groove is evident and more than 5 or 6 thou deep, get the crank repaired or speedy sleeve it yourself, re-fit new rear main seal, re assemble, bleed clutch if it's hydraulic and no more leak.
Sep 05, 2013 | Cars & Trucks
Installing piloet bearring in flywheel
Hi Snale, The bearing is located inthe center of the fly wheel. To gain acsess means removing the gearbox, clutch assembly and flywheel. Gain access from the back of the flywheel. Tap out the failed bearing, fit in the replacement and refit the flywheel. Make sure to torque the fly wheel bolts to the required specs. This is a major undertaking and even though the bearing is very small the job is very big. Regards John
Nov 16, 2012 | Cars & Trucks
I am tring to fix my fly wheel I think it's the fly wheel any ways I think there is a bolt loss where is the dam thing on this and anyways i just need a web site to be able to find it and how to take it...
Perhaps we are thinking of something completely different to each other. The flywheel sits slap bang between the engine and the gearbox and either, usually the gearbox, has to be removed to gain access to the flywheel. Here is a picture of what goes up to make up the flywheel and clutch assemblies, the flywheel is the part on the left and is bolted to the crankshaft through the six holes near the middle. Come back to me if you need anymore clarification.
images?q=tbn:and9gcsrvbgx14s0yhqqthg-bzqlsoqml2ols1fwh1yqkzcjco_gofjgy7v7qyu0
Apr 14, 2011 | 2001 Ford Focus
How do I access headlight bulbs on a 2009 Dodge Ram 1500?
I hope describes correctly the detail procedures for replacing 2009 Dodge RAM 1500 Headlight Bulb.
- First, open the hood; Disconnect the negative battery cable;
- Remove the four grille attachment bolts;
- Remove the grille;
- Remove the two headlamp assembly attachment bolts;
- Then reach into the front wheel house ahead of the front wheel to unsnap and lift the cover over the access hole in the front of the wheel house splash shield.
- Access to the bulb retainer can be gained through the wheel liner hole (see picture).
After that reach through the access hole to access the rear lamp retainer and remove headlamp assembly (see below picture).
Disconnect electrical connectors, and replace the bulbs.
Good luck (remember rated this help).
Nov 26, 2009 | 2007 Dodge Ram Truck
Do i have to remove the back seat to take rear struts off
Answer
REMOVAL - SHOCK ASSEMBLY
NOTE: Access for the nuts attaching the rear shock assembly upper mount to the vehicle is through the inside of the trunk.
Roll back carpeting on top of the rear shock tower to access shock mounting nuts.
Remove plastic cover from the top of the shock assembly.
Remove 2 nuts attaching the shock assembly upper mount/spring seat to the shock tower.
Raise vehicle on jackstands or centered on a frame contact type hoist. (Refer to LUBRICATION & MAINTENANCE/HOISTING - STANDARD PROCEDURE)
Remove the rear wheel and tire assembly from the vehicle.
Remove two fasteners holding the splash shield to the shock assembly upper mount.
Remove bolt attaching shock absorber to rear knuckle (Shock Absorber Attachment To Knuckle).
Remove the shock absorber from the rear knuckle first when removing the shock absorber from vehicle by pushing down on the rear suspension.
Move shock assembly downward and tilt top of shock outward, then remove shock assembly from vehicle through top of wheel opening
Nov 23, 2009 | 2002 Dodge Stratus
Procedure to repaloce rear shocks
Removal & Installation
  1. Remove the tire and wheel assembly.
  2. Support the control arm with a jack stand.
  3. Remove or disconnect the following:
  4. Electronic Ride Control (ELC) air tube from the shock
  5. Two bolts securing the shock to the control arm
  6. Trunk trim to gain access to the shock upper mounting nuts.
  7. Cover, the two nuts, and the reinforcement from the top of the shock
  8. Shock from the vehicle
Here are links to more diagrams. Best of luck on your repair.
Greg
http://www.chiltonlibrary.com/content/images/7922/images/7922UG21.pdf
http://www.chiltonlibrary.com/content/images/7922/images/7922UG22.pdf
May 20, 2009 | 2000 Buick LeSabre
Are their any speical problems or tricks in replacing air adjustable rear schocks on a 2001 buick custom
    0900c152802427b0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Use support bracket tool J-23028-01 mounted on a jack to support the rear lower control arm
    Electronic Ride Control (ELC) air tube from the shock Two bolts securing the shock to the control arm Trunk trim to gain access to the shock upper mounting nuts. Cover, the two nuts, and the reinforcement from the top of the shock Shock from the vehicle
    0900c152802427e1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Remove the cover to gain access to the upper shock absorber mounting components-rear suspension
    0900c152802427e2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Exploded view of the lower shock absorber mounting to the knuckle assembly-rear suspension
To install:
Install or connect the following:
Shock, reinforcement, and the two nuts. Tighten the mounting nuts to 15 ft. lbs. (20 Nm). Shock cover Trunk trim Shock-to-control arm bolts and tighten the bolts to 18 ft. lbs. (24 Nm) ELC air tube to the shock. Tire and wheel assembly
Apr 09, 2009 | 2001 Buick LeSabre
How to replace headllight lamp
I know your frustration! I cannot believe the complexity of changing the headlights. Chevy has tried to make this a dealer item only just to change a headlight bulb. I will try to explain the procedure unfortunately I do not have photos. First you will need to remove the wheel well liner (two bolts and two plastic push pins). Pull the wheel well housing back (you will need to turn the wheel/tire to gain access) and using a 7mm socket remove the plastic support piece that holds the bumper in place (two bolts). Pull the corner of the bumper down until you can locate the bottom bracket of the headlight assembly that is held by a 10mm bolt. Remove it. (Oh did I mention this is a two person job!) Next move to the front of the vehicle (hood up) and remove all the 10mm bolts holding the upper part of the grill (I think there are eight of them). Now remove the obvious top two bolts on the headlight assembly! With two people - one to work the headlight assembly and one to push down the bumper and pull out on the grill assemble, slowly and carefully pull the headlight assembly straight forward. You will need to be mindfully of the small tabs on the headlight assembly that like to get caught on bumper/grill. If you are just replacing the bulb, you should be able to move the headlight assemble far enough forward to gain access to the bulbs without totally removing the headlight assembly. What a ***** job! SHAME on GM.
Oct 11, 2008 | 2008 Chevrolet Suburban
Toys Logo
29 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
