Question about iRobot Roomba 530 Robotic Vacuum
It keeps spinning on the spot and then stopping with the red light flashing
  • 31 Answers
Your bump sensors are malfunctioning. I had the same problem. The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great. I'd recommend..
Posted on Sep 20, 2011
How to fix my dc 62 red light keeps flashing AFTER I WASHED IT
sounds like you battery is dead. Take it to your local vac shop for diagnosis.
Feb 19, 2015 | Vacuums
Room a 620 keeps stopping
It could be clogged with hair (when was the last time you cleaned it out?), it could be the battery isn't holding a charge any longer. It could be getting caught on something . How long is it running before stopping? I found I used to get about a two hour run from my Roomba, before the red light flashed. Then I started to unplug the charger and Roomba when it had a full charge and it wasn't needed. I noticed that after this the Roomba didn't run as long, maybe one hour, before needing a charge again. I leave it plugged in all the time now.
Jul 07, 2014 | iRobot Roomba 560 Robotic Vacuum
My Power head on my Dyson Animal DC39 will not stay spinning. Suction Issue?
There should be a red insert on the right-hand side on the cylindrical bulge behind the brush cylinder. Check that this is moving when you push the button. The red insert should stay pushed in for the brush to rotate. The insert moves in an out as well as rotates in order to lock in the 'in' position. Mine is a little sticky on the rotation and I need to shake the brush head a little in order to get it to rotate and lock.
Jan 05, 2013 | Dyson DC39 Animal Canister Vacuum
Once vacuum is turned on and switched to a certain carpet level, the red light begins to flash and the brush stops spinning. How do we fix this?
The brushbar is designed to stop rotating if you've set it at a level too low for the pile of the carpet you're trying to clean. The indicator light will flash to warn you of this. Using the cleaner with the brushbar raised to the next level on the selector pad should prevent this issue from occurring.
If you have any further concerns about your vacuum, please get in touch with us directly on 1866MYDYSON. One of our experts will be happy to provide the assistance you need.
Kind regards,
Jack
Dyson Online Customer Support
Sep 24, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Dyson DC28 brush will not spin, red light flashing
I cleaned the rollers and washed the rollers. I even cleaned the filters but light is still flashing on all floor levels
Jan 18, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
Spins, red light, many many beeps
look for 9 beep problem in FixYa
or see here
good luck
Avi
Apr 06, 2010 | iRobot Roomba 560 Robotic Vacuum
My i-robot spins first to the right, moves back a little, then spins again. after about a minute it stops the red light flashes it says oh oh and beeps nine times. how can i fix this?
Hey
Please look for other same problem posted here ;-)
You are probably facing a bumper sensor issue.
Try to clean the bumper first and if this goes on, either call iRobot service, or
take a look at this page for the step by step 9 beep fix.
Have fun
Avi
Sep 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Backs up spins in circles, then red light flashes and beeps
Sounds like either the battery is bad or not being charged properly with subsequent loss of programming.
Jul 23, 2009 | iRobot Roomba 500 Series Virtual Wall...
Miele SEB-213 powerbrush stopped working
Pull the head cover off to check the belt, if the belt is ok then it might be the power connection between the handle and the power head shaft. If the red light is on the power head, then its not the connection
because its getting power. Now some heads have a reset button on them,you could check this also.
With the cover off the power head, remove the belt, now turn it on, and be careful, but try to make the motor shaft spin,with one finger, because if it does start to spin you do not want to hurt your finger.
If the motor starts to spin,put the belt back on, if it does not spin again, the motor is too weak.
If it does not spin at all, the motor is bad.Hope this helps you,and you get it working.
Mar 24, 2009 | Miele SEB 213-2 Vacuum
iRobot Roomba 530 Robotic Vacuum Logo
80 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
