Question about Whirlpool GS6NBEXRL Side by Side Refrigerator
This fridge has been a repeat problem, but not the same problem twice! We recently replaced starter relay, now the water thru the door has stopped working. Ice Making is fine, when you press water button you hear click, and the measuring counter starts moving, but no water. I suspect bad water valve, or solenoid which isn't opening water.Removed water line, and water is present before the valve. Thoughts?
  • flipr2922 Dec 31, 2010
    Flipr here, found the issue, the water storage in the fridge, (white plastic wavy thing) had evidently frozen, as I couldn't blow air thru the lines.
    Pulled it out, thawed in sink of warm water, everything is good. Thanks all for the help. Digging deeper saved me $80 buying a new valve.
shaggyrat
  • 1224 Answers
SOURCE: Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
Posted on May 15, 2008
SOURCE: Whirlpool Gs5shaxnb02 Ice maker
HI!
In my refrigrator ice is not making . My frig is about one year old side by side. All of a sudden I noticed water stop coming in the ice dispenser. Please advise me what went wrong.
Thanks
Posted on Aug 18, 2008
SASSYBEAR
  • 148 Answers
SOURCE: Whirlpool Dispenser Problems
it is possible that the water line has frozen, but I would venture to guess that it is most likely the water inlet valve. Both can be accessed by removing the back panel on the back of the fridge down at the bottom.
Posted on Oct 21, 2008
tborn6
  • 700 Answers
SOURCE: My whirlpool fridge, ice makerMy Whirlpool is not making ice. It has an in door ice dispensing system. It stopped making ice yesterday - what could be wrong?
lift the bar up to shut the maker offf and then turn it bakck on and wait.
Posted on May 27, 2009
SOURCE: ice maker stopped making ice. water works fine
chande the filter
Posted on Jul 12, 2009
Emerson model#CR519B. The unit just stopped working. If plugged in a motor runs for about 8 seconds and clicks off; about a minute later it repeats. Help
I had the same problem with a small wine cooler. It happened to me twice in 6 years. Both times I had to replace the starter relay.
I couldn't find any repair facilities willing to work on these small wine coolers or refrigerators, probably because the bill would be more than the used fridge is worth. If you feel confident around a volt/ohm meter and electricity, you could learn how to test this and maybe fix it yourself.
You shouldn't do any of this if you aren't familiar with using a Volt/Ohm meter and can safely and confidently work around electricity.:
  1. Unplug the fridge
  2. I first tested the compressor with an Ohm Meter (see how with youtube video below or by reading how at Davesrepair.com). It was good, but it kept starting and stopping within a few seconds.
  3. Basically my starter capacitor/relay wasn't working. It supplies temporary starting voltage to the starter relay in the compressor, then cuts off to allow the motor to run.
  4. I bought a Supco 3-in-1 on Amazon for less than $13 and hooked it up according to the supplied instructions. It lasted about 3 years.
Of course, the factory recommended repair is to buy the original replacement relay, but it will be more costly and harder to find.
I bought a Supco 3 in 1 Hard Start relay sized for the HP on my compressor. Mine was the Supco RCO810 (see link below).
NOTE: Before I replaced the starter relay and overload protection with a Supco 3 in 1, I learned how to test the compressor with a Volt/Ohm meter. If you don't have a meter, you can buy them online or inexpensive to free with a coupon at Harbor Freight.
Feb 15, 2015 | Emerson Refrigerators
Water won't dispense
Which pump did you replace? Are there a few?
May 13, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Whirlpool fridge
Bad wiring or faulty sensor would cause the relay to be activated and tell the solonoid to open whenever it likes. I would replace the door switch or see if it is sticking otherwise you may be looking at control board problems
Sep 06, 2012 | Whirlpool Refrigerators
My 8 year old fridge has stopped producing water and ice through the door. What could be the problem?
Hi
If you have not recently changed the water filter, then do so, then flush through to draw off around a gallon of water.
It should supply water then 12 hours later you should get ice
Regards
Gordon
Apr 24, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
We have a 25.4 cubic Whirlpool side-by-side fridge/freezer stainless steel look. Since the last 2 weeks....the display lights showing temperatures in fridge and freezer the front water/ice dispenser unit...
the clicking is from the lamp relay which makes the lights flicker and its located on the units rear area in the back,without a model number i cant tell what this boards model number is but you need to replace this whole board as they are non repairable(this is usually caused by a power surge or outage,which can destroy these boards,also even if a lamp in the unit burns out this can destroy this board too)
Mar 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Fridge freezer not working alarm sign (triangle)
replace the "ptc-overload-relay" on the compressor and this will take care of your cooling problem,its easy to replace,unplug the old component and plug in the new replacement component
Apr 02, 2010 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
Water build up under crispers the fridge is a maytag & has been moved here recently could it be that the fridge in not level or that the drain for the defrost cycle in possibly plugged please give me...
check door to make sure it is sealing correct warm air might be causing condensation in fridge area or check drain freezer -may be clogged causing water to trickle down thru vent at back wall by fan
Sep 26, 2009 | Maytag Refrigerators
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool GS6NBEXRL Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
