Question about Dryers
Repair manual for kenmore dryer model # 11087562601
  • 26 Answers
SOURCE: Kenmore Dryer, Model # 11063102100, does not dry.
Does the drum still turn. If so probably just needs a new heating element. VERY easy to replace. Usually instructions to replace on or in new element box or just google instructions.
New heating element would be my first move to repair dryer.
Also, if you use softeners or dryer sheets, Wash lint screen with dawn and soft scrub brush to remove oils and residue (even if it dont look like there is none there there is) to extend your heating element use.
Posted on Sep 26, 2009
  • 2468 Answers
SOURCE: kenmore elite oasis dryer model #110.6708
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Posted on Mar 19, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Repair manual for Sears Kenmore
This manual should help you with access and component changes:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/3ffad75038c96fe4852571ca006cb80a/$FILE/L-58.pdf
There is a tech sheet inside the dryer. It should be in an envelople taped to the cabinet. Depending on the machine service / repair history, they sometimes are in the upper console. It should also include the wiring diagram.
If you need to replace just the belt this link is pretty straight forward on how to accomplish the task:
http://repair2000.com/wpoolbelt.htm
Thanks for choosing FixYa.
Kelly
Posted on Sep 03, 2010
blueextc3221
  • 15935 Answers
not much more than a service call for 1 hour work.
Rates vary depending on location.
Expect $60-$80 plus parts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
hunter19_46m
  • 7482 Answers
SOURCE: we have a loud squeaky
Hi chazt3
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
Posted on Jun 27, 2011
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Why won't it start?
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Dec 12, 2015 | Kenmore HE5 Electric Dryer
Owner's manual
kenmore dryer 29inch http://www.hammerwall.com/Download_Manual/45407/
manageMyLife
7Conversations
0 0 Ratings
Rate this!
KENMORE Residential Dryer Find parts for your model number at Sears PartsDirect: 11066722690, 11066801690, 11068702890 view more
Schedule Repair - Purchase Products - Ask an Expert
Click here to download manual.
Apr 06, 2012 | Kenmore Dryers
787207L Do It Yourself Dryer Gas and Dryer Electric Repair Manual For Kenmore brandWhat's your problem?
Your model number is wrong. Kenmore features many different brands under the kmore name. You must be more specific
Jan 17, 2012 | Dryers
The dryer basin will not turn when drying. Kenmore dryer Model # 66722692 Serial # mh0566762 Type 180-00
That's probably a broken belt:
Unplug the dryer and take it outside. While you are at it get a belt
(341241 being the most popular one) Get some zoomsput oil (it is safe for dryers).
Service manuals, repair videos, and more HERE
May 06, 2011 | Kenmore Dryers
Is there a kenmore model 417.9402500? Looking to buy one used and need repair history
Couldn't be a better dryer on the planet. This is non other than the old tried and true Frigidaire type dryer Here is a companion manual for late models.
These rarely break down and when they do the parts are fairly priced and easy to obtain and the repairs are very easy. I highly recommend it.
Feb 28, 2010 | Kenmore Dryers
Dryers Logo
135 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
