Question about Loewe Concept L26 26 in. LCD TV
Its difficult to starting the tv from standby! Type Loewe L2650
My loewe 34" tv calida 5684Z shows red when it is switch on, it clicks then shows green, boost sound in the screen, then return to red and remain at standby and wouldn't start
Sounds like Red cathode voltage problem. Contact any service technician. The video output section to your TV need to be checked. One color predominant screen; is the problem.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 27, 2014 | Televison & Video
I get problem with my loewe television concept L26 that remains stand by even you switch it on using remote. at the power supply circuit only 5V can be seen at connectorW652 and connector W651 no vol
Just understand, that the 5V supply you measure comes from the power supply is used for standby and power On switching purpose. As far as this supply voltage is OK, the fault must be to its main board, because, from the main board comes the power up start voltage back to power board to initialize its whole working.
Check the main board. The power supply regulator board is now Ok; otherwise, you can't get this 5V supply line active. Contact any service technician.
Jun 25, 2014 | Loewe Concept L26 26 in. LCD TV
Press the power button in and TV tries to come on but fails
Common problem with this model is the line output transformer.
Jan 07, 2014 | Loewe Aconda ACO9303 30" TV
Remote no longer puts TV in standby
I found an original replacement remote for a Loewe ARC332PB at remotes.com
Sep 30, 2009 | Loewe CAL232 TV
Have Loewe Concept 84-100. Push power switch and set clicks on and off showing standby red indicator and then ready green indicator at about 2-3 second intervals, but nothing happens ie no picture no...
I've read on your site where a number of others have had this problem and on the strength of that have talked to a local technician who has more or less agreed - so will go with his expertise. Many thanks for your interest.
Jul 06, 2009 | Loewe Aconda ACO9383 38" TV
Tv won't turn on
yes but you have to open the tv
Mar 01, 2009 | Loewe Aconda ACO9303 30" TV
Loewe Vitros 6370- won't turn on!
its a power supply problem.
Jan 13, 2009 | Televison & Video
Loewe Aconda 9383-S TV
flyback transformer...get a pro to fix it
Jan 27, 2008 | Loewe Aconda ACO9303 30" TV
Will not switch on
If the sound is like an electrical arcing from the back left as you look at it the probable cause is the LOPT (Line output transformer) get this repalced and the set should be good.
If it as a clicking from just behind the front controls, the 5V standby transformer needs replaced.
Nov 01, 2007 | Loewe Aconda ACO9303 30" TV
Loewe Concept L26 26 in. LCD TV Logo
60 people viewed this question
Top Loewe Televison & Video Experts
Computer Repairing
Computer Repairing
Jerry Umali
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
