Question about Hotpoint Washing Machines
Hi, My hotpoint Aquarius WMA50 washing machine has just sparked and blown all the electricity off. I changed the fuse but this had no effect. All the dials are off and the machine will not come on. My wife said it was making a funny noise just before it blew. Any ideas or assistance gratefully received??....Thanks.
  • 784 Answers
If your machine is sparking I would say that you should unplug it and not use it --- call a service tech to check it out and see if it can be fixed.
( that unit is now a fire hazzard and a short in the system is obvious,, don't take any chances ).
c...
Posted on Dec 31, 2010
I believe I have blown a fuse in the machine
Some washers have an electrical anti interference devise fitted, in some cases this blows out.
Dec 19, 2013 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1000 (wma50p) not taking in water, and i cannot move the drum by hand.
Hello, it sounds like the main motor has blown. This causes the pump to stop as it is connected to the pulleys and gearbox. The only solution is replacing the main motor. Even though it sounds expensive, it should only cost around $100 plus fitting.
Mar 23, 2011 | Hotpoint WMA50 Front Load Washer
My hotpoint washing machine (model wma50) will not start due to the door lock light flashing yet the door is closed
common problem on these machine's, you need a new door handle which comes as a full assembley with spring and all attached.
open the door, using star screw driver remove top and bottom screws along with two near the catch.
the doo wil split enough to remove old handle and fit new 1.
Oct 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Where is the water filter kept on the hotpoint aquarius wma50
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum, filter is located inside the hose.
Sep 19, 2010 | Hotpoint WMA50 Front Load Washer
Hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Jul 27, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Hi, i have a hotpoint aquarius 6kg wma50, my
Have you checked for blockage in the pump. Or the have been some problems with a ball that sits in the hose between pump and the drum. This can block the water. Check this berfore purchase new pump.
Jul 26, 2009 | Washing Machines
Washes but does not spin
I AM NOT A MECHANIC, BUT IT SOUNDS LIKE YOUR MOTOR COUPLING NEEDS TO BE REPLACED.
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wma50
The motor does not have provision for belt adjostment, it is self tensioning
To gain access to the brushes, you need to remove the motor from the washer.
Remove rear panel, remove belt, unplug motor lead, taking note which way the plug goes,undo screws securing motor, and lever motor back with a screw driver, remove motor and change brushes.
Feb 12, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I need to change the door seal on a Hotpoint Aquarius WMA50
Basic diy tools should be ok. Take out lid screws behind plastic caps on edge(will be stars but small flat will do it).Lift front of lid and push back to remove.Remove kick plate and take out screws behind it.Remove band holding front end of seal and detach seal from rim of opening. Remove screws holding door lock and push lock through. Remove soap drawer & take out screws behind it.Carefully bring panel forward & slide to right to remove(Take care here with board &wiring)Remove screws holding front panel & lift front panel & remove it.Remove band from seal and your there.Note locating slot on seal. If possible get an extra pair of hands to hold panel with board to avoid damage.
Nov 16, 2008 | Hotpoint WMA50 Front Load Washer
Washing Machines Logo
102 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
