Question about Panasonic Televison & Video
No color on tv . I'm connecting my hp dv6000 laptop to panasonic viezo tv
    Master:
  • 691 Answers
You are saying you don't have color before you connect to computer or after?
Posted on Dec 31, 2010
Can I switch out the screen to my hp g60 535 dx laptop with a screen from an hp dv6000 laptop
That will be impossible. The screen from the HP Pavilion G60-535dx is a 15.6 CCFL LCD while the one of the DV6000 is 15.4.
I suggest buying a new screen for the DV6000 if you need to. Or go online and trade the screen of the HP G60 and use the fund acquired to get a screen for the DV6000.
Hope this helps.
Oct 28, 2014 | Computers & Internet
Tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 | Computers & Internet
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
Hello, I have a problem with my HP DV6000 laptop.
The video card. is out In that case I suggest to buy a new laptop because its more cheaper and transfer all the data from the old one to the new one.
Nov 01, 2013 | HP Pavilion Computers & Internet
How can I connect my pc to tv
The DV6000 has all the drivers needed to connect to a TV as long as the TV has either a s-video connection or a pc vga input. The vga input is usually blue in color on the tv but on the laptop it may appear dark tan or brown and does not have screws to hold it into place, the plug just fits in and tension holds it in place. Once you connect the cables, change the input on the TV to the type of cable you are using. The laptop should automatically pick up the signal from the device and load the driver for it. The desktop should appear on the tv if the output signal and input are matched. The icons may appear different on the TV if the resolution is not close to a match but that should not be a concern unless it is cutting some of the picture off, in that case all you have to do is change the resolution to one that is easier for the tv to show. The dv6000 allows you to toggle through the video output settings by holding down the Fn key and tapping the F4 key, this will change the display to both laptop lcd and tv, just tv, just laptop lcd etc. It will even let you extend the desktop from the laptop to the tv or from the tv to the laptop, making one long display side to side.
Nov 28, 2009 | HP Pavilion dv6000z Notebook
I have a HP dv6000 laptop that needs a motherboard replaced. can you tell me how to do that?
hp has step by step directions on there website for full rebuild of the dv6000.. let me get you the link here now...
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
Sep 30, 2009 | HP Pavilion dv6000z Notebook
HP Palilion dv6000 can't connect to a TV
The first thing you need to do is after you connect the cables.. hold down the fn key and press f4. this should bring the screen on the tv. make sure your tv is in the AV mode. if not try with a vga cable.
However if it still does not show up then probably the display drivers are corrupted. reinstall the drivers from the recovery manager > advance options > hardware driver installation.
Hope this helps....
Regards,
Anup
Apr 07, 2009 | HP Pavilion dv6000z PC Notebook
Hooking up sony tv to HP laptop
Do you have a HDMI jack on your TV? it looks just like the blue/graphics/monitor jack on your laptop. If so use it to connect and you should be able to use your tv as a monitor. (if you tv came with the HDMI cable?, if not you can purchase one ez enough from Radio Shack)
Check your users manual for directions on how to use the remote to get it to that function. My Hansphree TV I have to put it on AUX to use my laptop hooked to it and see my TV as my lappy monitor.
Hope this helps you and others! Good Luck.
Feb 17, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Plz help my laptop has no display dv6000
More info please. Does it show a boot screen first then go blank? Does it beep when you turn it on? Has your display flickered recently or have the colors shifted?
Jan 04, 2009 | Computers & Internet
Televison & Video Logo
27 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
