Question about Asrock P4i65G Motherboard
How much RAM can this mother take and what type?
  • emmanuel_far
    emmanuel_far Oct 02, 2012
    Can this motherboard take 4GB of DDR400 memory
  • 554 Answers
Max. capacity of system memory: 2GB Supports DDR400/333/266 non-ECC, un-buffered memory
Posted on Dec 31, 2010
Testimonial: "really helpful and quick answer. Many thanks. Dr Peter Swinyard www.phoenixsurgery.com"
Esonic mother board ram problem. i was changed ram but still beeping. psu changed but still beeping. what i should?
Make sure that you are inserting the correct type of ram - many mo bo's are very sensitive to what you throw in there and will not work with just any ram. Put in the exact stuff called for by the manufacturer.
And are you sure it is a ram problem? There are beeps for other hassles other than ram. Check that out.
Aug 19, 2015 | Computers & Internet
PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard: RAM IS NOT WORKING. SUPPORTING RAM REQUIRED, CAN Y...
*********** supports DDR1 type Ram, you can easily get it from the market. Just ask the retailer to give you the DDR1 Ram, they will ask you how much memory of Ram you want. There are 256Mb, 512Mb, 1gb, 2gb, etc.. the more the better and this motherboard supports upto 2 gb, but some newer make of this motherboard miht have been changed.
May 17, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Need to buy a new Mother Board?need some help
Now a days every motherboard is come with PCI-Express Slot and this mothrboard can also handle more than 3.0Ghz CPU and it support DDR2 RAM which is faster than DDR1 RAM.
High FSB and high storage of DDR2 RAM will increase your computer performace.
DDR2 RAM FSB is depend on your motherboard choice. Because your motherboard should be able to support your RAM FSB rate.
Mar 05, 2009 | Intel Motherboard
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
Type fo Ram and Compatible graphic card
You can look up you mother board on the MSI support website. You wil need to know the CPU  socket type. Download the manual for the board and the RAM and recomendations or in the manual.
http://global.msi.com.tw/index.php?func=downloadindex
Jan 18, 2009 | Intel Motherboard
How can I convert 1 GB Ram into Mother Board 810 E?
YAS IS GOOD YOU CAN UPGRADE YOUR MEMMORY TI 1GB ALL YOU NEED TO DO IS GET THE EXACT TYPE OF WHAT YOUR MOTERBOARD IS USING eg IF YOUR MOTHERBOARD IS USING DD RAM GET 1GB DD RAM IF IT SD RAM YOUR BOARD USES THEN GET SD RAM. IT GONNA BE FINE WHEN YOU UPGRADE IT WILL PARFECT YOUR PC PERFORMANCE.
Nov 20, 2008 | Intel Motherboard
Ram
This motherboard only supports DDR1 type of RAM that's why the new RAM wont work, to see the
complete details about this mother click this LINK
Nov 07, 2008 | Mercury P4VM800M7 Motherboard
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Mother Board and And Ram
You dont say how much ram you have currently, so go to this site to inform of the type of ram you need. http://www.crucial.com/
Sep 20, 2007 | E-Machines eMachines Desktop PC
Asrock P4i65G Motherboard Logo
121 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
