Question about Honeywell Programmable Thermostat Heater
Istor programmable timer only shows EEE after reset.
CAN I PGM JUST THE TIME THE TIMER IS TO GO ON AND SHUT OFF WITHOUT RESETTING EVERYTHING LIKE THE CURRENT DAY ,TIME ETC.
Usually yes ... with modern timers.
The manual will show how to change programs... and this information is normally one of the last things shown in manual, or sometimes will say in same section that shows how to program timer.
Some older timers, some outdoor timers, and some battery-operated timers you must remove battery or unplug timer to reprogram
Following links can help identify timer and download possible manual.
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/Programmable.html
http://waterheatertimer.org/Boxtype.html
Gene
Water Heater Timers Save Money
Mar 13, 2015 | Hardware & Accessories
What does a flashing "on" mean? The timer does not work as programmed.
The attached page is long but will show you how to reset and program your wall switch timer
May 27, 2014 | UPM Programmable Wall Switch Timer
How do you delete a program Intermatic hb88rc
Try removing battery, and then reprogram timer.
Some timers are reset when battery is removed.
Newer digital timers keep programs in memory when battery is removed, but in that case the instruction manual shows steps for resetting timer and deleting programs.
The HB88RC manual does not show steps for deleting programs or resetting timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
Sep 21, 2011 | Intermatic HB88RC - 7-Day Programmable...
The programmable timer/switch has stopped working. LCD shows nothing. Pressing the door no longer turns light on and off. Flipped breaker and no help. Seems like I need to buy another one after only six...
You posted under Aube timer.
http://waterheatertimer.org/Aube-timers.html
Aube timers have internal rechargeable battery that cannot be exposed to cold temperatures nor can battery be replaced when it goes bad.
Try resetting timer to see if function resumes.
Industry standard is 1 year limited warranty, so your product is under warranty.
The Aube T1032 is ordinary 7-day programmable, without astronomical capability, but it can be wired for single-pole or 3-way.
If you want same type of timer without battery, for single-pole only, Home Depot carries 15071
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Advantage: no battery, and this timer can be exchanged in-store without shipping costs.
Lowes carries Utilitec 0141244, for 7-day single-pole, without battery:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Lowes also carries 7-day & astronomic 0192773, single pole, no battery
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Apr 15, 2011 | Honeywell Aube by TI0323WU 7Day...
I have pressed reset on my grasslin qe1 timer and now nothing will work on it
Grasslin qe1 and qe2 manual does not show troubleshoot section.
http://www.grasslin-controls.co.uk/assets/graphics/static/QE1-QE2_GB%20instructions.pdf
1) Remove power to unit and see if it will reset.
2) Press reset and hold button longer
3) Manual says: SLIDE SWITCH MUST ALWAYS BE LEFT IN "RUN PRESET PROGRAMME" OR, "RUN OWN PROGRAMME" POSITION, OTHERWISE THE CLOCK WILL NOT RUN, AND NO SWITCHING WILL OCCUR.
4) Timer has stopped working. I test timers, and they all stop working one day.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 04, 2011 | Hardware & Accessories
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
Have model T1 032A programmable 3 way mfg 11-06 and bought in 07. Light still works manually by garage switch but no power at timer in house. Can't see a battery. Nothing shows on screen even when I push...
Open following link to identify timer and download manual:
The reset button is small round button and can be pushed with toothpick or paper clip.
If reset doesn't restore timer, then timer is probably shot.
Also check all breakers to make sure one isn't tripped.
Aug 28, 2009 | Aube Technologies Aube 7-Day Programmable...
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Our TH8000 Series Programmable Thermostat keeps flashing "change filter" even after we changed it. The guide book does not show how to re-set so the flashing stops.
try holding the filter button in for three seconds, if that doesn't reset the timer try the filter button and the temp. up button at the same time for three seconds.
Mar 30, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
55 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
