Question about Stoves 720EF Electric Double Oven
My fan oven works but doesn't heat up very well - only gets warm even though the indicator is clicking off and saying it's hot - eg 220c
  • 250 Answers
It sounds like the thermostat has gone faulty or lazy. As a check, I suggest you buy the round oven thermomater from Lakeland - I think it is about £5.00 to see what the actual temperature is being achieved. Also check the sensor in the oven. It is the long thin tube located at the top rear right hand side of the oven above the circulating fan cover. The sensor should be clean and bright not covered with grease etc as this may cause incorrect readings. Don't attempt to clean it manually as it is fragile - use a brush on cleaner - again from Lakeland and follow the instructions on the label. If you have to replace the thermostat you will have to take the whole oven out of its kitchen cabinet - the handbook tells you how to do this.
Posted on Jan 06, 2011
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
Hi. My oven stopped getting hot (elements still get barely warm) right after the temperature sensor broke off. Could the broken sensor cause this? Thanks.
yes it can and ur element is probably bad shut off power take out 2 screws on side of it n pull ito ut to disconnect wires n put new one in !!
Apr 07, 2011 | Ovens
Our fan oven will not warm up. Fan working but oven will not get hot.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 16, 2011 | Neff U1421 Double circotherm Electric Oven
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
Our brand new kitchen aid oven will blow hot air for up to a half hour after it has been turned off. This seems unusually long- what is the expected time of cooling off?
That depends on the ambient temperature in the room..if your room is fairly warm you can expect it to take longer then if the room is cool...
I would say though that 1/2 hour is pretty normal...it is good to get the unit cooled down, the less time it is warm the longer it will last... heat kills ovens...even though they are made to take heat...
heatman101
Apr 24, 2010 | Ovens
Fan forced heat not working
If it is an electrically heated fan oven, then it sounds like the oven element is not working.
This is usually located at the rear rof the oven behind a removeable cover.
Hope this helps.
Dec 05, 2009 | Ovens
My astro x oven will not heat up, the grill still
Sounds like the heating element has gone. if you can see thee element sometimes you can see damage like a hole or melted metal with white residue
Aug 02, 2009 | Fisher and Paykel Ovens
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
DeLonghi ESS601 electric oven
We just moved in to a place that has this oven, if you use the setting with the fan with a circle round it, seems to get hot! Don't know what the other is for though!
Hope it helps!
Pete
Jun 20, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Stoves 720EF Electric Double Oven Logo
80 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
