Question about Canon IMAGEPROGRAF IPF8000 InkJet Plotter Printer
Ink tank counter reset code for Canon ipf8000
  • Canon Master
  • 3,267 Answers
However, you have to perform the reset before the Maintenance Tank is completely full.
Once it is marked full, the printer won't start, even in Service Mode, until you replace the Maintenance Tank. If this happens, you can still reset the tank by inserting a new Maintenance Tank, start in service mode, then put the old cart back in and reset it
1. Start the printer in service mode (hold down Feeder Selection and Information while pressing power. Keep the feeder and information buttons down until you see an "S" in the upper right corner of the LCD.
2. Press "Menu". There will be a new entry called "SERVICE MODE" with a different menu structure and navigation system.
3. Familiarize yourself with the following facts while in this menu:
a. Left and right change the categories.
b. Down and up go into, and out of (respectively) submenus.
c. From what I've read, the service mode is very powerful - lots of opportunities to really mess things up. Be careful.
4. Select "Service Mode" as you normally would, i.e. scroll down, then press OK.
5. Press the right arrow until you see "Initialize".
6. Press the down arrow.
7. Press the right arrow until "W-INK" is displayed. (Note: be sure you select "W-INK" from the "Initialize" choices instead of "W-INK - CHG CNT" which sounds like just the thing, but doesn't work.)
8. Press OK.
9. The display should show "=W-INK" for about half a second, then plain "W-INK".
10. Press up until you get back to the main menu. Press information until the maintenance cartridge capacity is displayed.
11. The maintenance cartridge capacity is now 100% (aka empty).
12. Press and hold Power to turn off your printer.
13. Turn it back on normally.
14. Maintenance cartridge capacity (not usage!) should still be at 100%.
Posted on Dec 31, 2010
Could you provide the procedure for resetting the wast ink container for this printer? Thx.
The waste ink cartridge in these machines has a chip on it. The chip resets the ink count. You may be able to find an aftermarket chip on line somewhere. However I did find this which may help.
canonipf Reset Maintenance Tank
Jul 09, 2015 | Canon imagePROGRAF iPF8000 Printer
Wat tank full mp 520
Hi Guy,
I believe that what you mean is 'Waste Ink Tank Is Full' error on Canon MP520.
To fix this problem, first you need to reset waste ink counter of the printer then you should replace the ink absorber with new one.
In order to reset waster ink counter properly, you can read complete procedure how to reset waste ink counter of the printer below:
How To Reset Waste Ink Counter Canon MP520 Multi Function Printer
May 07, 2014 | Canon MP520 All-In-One InkJet Photo...
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
<Remedy>
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
Dec 06, 2009 | Canon SmartBase MP390 All-In-One InkJet...
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
Canon IPF 8000 does not recognize ink tank
thre was a part of inks that didn't worked....so there is no problem of the machine but problem of the chip
Apr 15, 2009 | Canon imagePROGRAF iPF8000 Printer
Resetting maintenance ctg for canon ipf8000
You can reset it from the service mode it will take you 15 sec but you can use it only for service reasons.
If you reset it there is danger to fload with ink and messed up the whole area.
Jan 18, 2009 | Canon imagePROGRAF iPF8000 Printer
Reset Ink Tank for Canon IPF 610
How do you reset the waste ink tank on the IPF700? Would appreciate it if someone could help me.
Thanks
Nov 10, 2008 | Canon imagePROGRAF iPF8000 Printer
Waste ink tank full
please help me for repair waste in tank full canon ip3300.
Nov 01, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon IMAGEPROGRAF IPF8000 InkJet Plotter Printer Logo
1,430 people viewed this question
old marine
old marine
