Ebac 2600 e dehumidifier Failing to collect water. Everything else on the machine functions correctly.
koolbreezes
  • 540 Answers
SOURCE: Replacing the water container in
Checkout the manufacture webpage and model #'s .
Posted on Sep 03, 2008
SOURCE: collecting very little or no water
Given all other variables are the same (location, average humidity, humidistat setting, etc.) I would speculate either:
- the compressor is not running as much as before, or
- the evaporator is icing up and blocking ariflow, or
- the compressor is not getting evaporator coils cool enough, or
- the fan is not running at top speed.
Have you checked for icing?
Has the humidistat setting been inadvertently changed?
Does the fan seem to be operating normally?
Do you hear the compressor "kicking in", or is it just the fan you hear?
Posted on May 07, 2009
VtToolMan
  • 704 Answers
SOURCE: Dehumidifier not collecting the water
This isn't something that regular homeowners can do themselves, as you need to have technical training in order to remove and recharge refridgeration/dehumidification units.€
Unlike most cars and trucks that can easily be recharged with Freon kits from a local auto parts store, most refridgeration appliances require a special set of charging gauges and different refridgerents to accomplish the task. Some of these consumer products don't have charging ports eithe, meaning that a tech will have to cut into the system to make the repair.
With that being said, try taking off the front grill and/or covers to vaccuum off the coils and the evaporator. Since dust and dirt can accumulate in these parts, it will cause the unit to run hotter and be less efficient meaning it won't be able to cool as well or extract as much moisture (condensate) from the air.
Also, remove and clean/replace any air filters you have - let them air dry before replacing them, as wet filters create too much back pressure on the system.
Hopefully all you have is a dirty, clogged unit and a good complete cleaning will get your unit running well again!
Hope you find this Very Helpful and best regards!
Posted on Aug 26, 2009
heatman101
  • 43501 Answers
SOURCE: Ebac xl Dehumidifier not collecting water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
heatman101
  • 43501 Answers
SOURCE: My Dehumidifier has stopped dehumidifying!
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Posted on Dec 12, 2010
My ebac 2000 is making a noise and not collecting water
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
May 23, 2011 | Ebac Dehumidifiers
I have a Ebac Homedry 660 dehumidifier. How can I tell if the demidifier is defrosting?
If it was frozen and is now thawing, you will probably find some water in the collection container and some on the floor.
Mar 09, 2011 | Ebac HD880 Dehumidifier
There is a lot of water leaking out of the bottom of the ebac and not collecting in the unit.
try to check the water leakage or the origin where water comes from or maybe the area where unit locate was a very hi. humidity.
Feb 05, 2011 | Ebac Dehumidifiers
Coils do not get cold
heatman101
Sep 14, 2010 | Ebac BD80 Dehumidifier
I have a EBAC 2800E. The problem is it does not dehumidify. When the equipment is switched on the motor runs and it gets warm but it does not produce any water in the tank. Does this indicate that it...
heatman101
Aug 23, 2010 | Dehumidifiers
Dehumidifier runs but doesn't collect water
heatman101
Jun 09, 2010 | Kenmore 54501 Dehumidifier
It collects some water but it also spits water out
The dehumidifier has a non-removable tray under the coils (they look like radiators) that collects and drains the water away. If the tray or drain gets clogged with dirt or slime the water doesn't drain away well. Some water is picked up by the fan and is blown out the vent. Take the covers off the machine and give everything a good cleaning. If you get water on any electrical parts, let the machine dry thoroughly before plugging in.
Nov 12, 2009 | Frigidaire FDL50R1 Dehumidifier
heatman101
Oct 11, 2009 | Ebac CS60 Dehumidifier Dehumidifier
Just replaced fan motor,and blade works fine,been running for 4 days,but no water collected,in container home homedry 660
These are somewhat related to cooling systems so the system may need a coolant recharge like any AC. Check your user guide to see if there is any mention of a need for recharging.
Oct 04, 2009 | Ebac HD880 Dehumidifier
Dehumidifier leaks
Either there is a hole/leak in the tray, or the drain line is clogged. You are giong to have to access the tray to determine this: standing water is plugged line and no water is busted pan. This will determine your avenue of approach.....
Aug 31, 2009 | Ebac Neptune Dehumidifier
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
