Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
It won't turn on - Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
  • Dyson Master
  • 17,130 Answers
Please check the power from the main plug to the unit. If this is present then the mains switch must power, if not the switch can be faulty or else a possible motor failure.
Posted on Dec 31, 2010
Won't turn off
It's highly probable that the Dyson power switch has gone bad.
You can buy dyson dc14 switch here.
The switch is located right behind the front covering of the neck or handle when you remove the telescopic wand. Please make sure that the vacuum is unplugged before you start this project.
May 27, 2013 | Dyson DC14 All floors Bagless Upright...
Neato vacumm won't turn on
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Apr 17, 2013 | Neato Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Dyson won't go down, stay upright. As I forced it down and turned it on it started smoking. I unplugged and cleaned out by brush but it still won't go down and continues to smoke when turned on....
I'm sorry to hear you're having difficulties with your DC07. I'd advise against turning the cleaner on again, and encourage you to get in touch with us directly so we can help resolve this issue for you as quickly as possible.
You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 26, 2011 | Dyson DCO7 Animal Bagless Upright Cyclonic...
The dyson won't turn on
Sorry to hear you're having difficulties with your DC14. If it won't turn on at all, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting steps over the phone with you. If you're based in the UK, you can call us free on 08002980298. If you're based in the US, you can call free on 1866MYDYSON. We look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 30, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
98 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
