Question about Zanussi TC7102W Electric Dryer
Zanussi 7102 won't start. Power is ok. Condenser tank full light remains partially on even when tank is removed. When startbutton is pressed condenser full light illuminates fully. Water pours out pipe at back of plastic condenser tank, this was previously sealed and water had to be poured from 2 inch hole on top by removing cap. Pat McGinness
  • Anonymous Mar 28, 2014
    No previous issues drier had. Previously worked but now won't start when pressing start button even though power light is on. Water container is empty and the light is out no smell of burning, any idea why machine won't work
  • 3 Answers
Pat, Have you found a solution to this yet? I have got exactly the same fault today ! Having taken the top & left side of the dryer off, I found what looks like a broken drive belt - not the main drum drivebelt which is fine, but a shorter one (about 18cm diameter loop) with no obvious place for it to have come from. Any clues would be appreciated. Dave (drdave@fsmail.net)
Posted on Jan 04, 2011
Hello I have a Zanussi TC 7102 condenser tumble dryer which has suddenly stopped working. It now makes a noise that sounds like it is about to start turning - except that is doesn't turn.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Feb 14, 2015 | Zanussi Dryers
Zanussi condenser dryers
It can be mechanical or electrical malfunction. I would check tank microswitch, float and lever.
Below is explained how the condensate drainage system works and that will facilitate fault detection.
The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
Dado
Aug 10, 2014 | Zanussi Dryers
Why does the condenser tank full light come on even though its empty
Hello, before call the specialized service try this:
Turn off and unplug the dryer from the main supply.
Open the main door of the dryer and with your hand attempt to move the drum up several times.
I have a Zanussi Electrolux TC7103W condenser drier and for some reason the empty water light keeps coming on even though the reservoir is usually only half full. I have tried emptying it and tried un
Make sure lint build up is clear behind condenser
Sep 29, 2012 | Dryers
Start/Pause light flashes, won't start. No error code. Pump or hose blockage?
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jun 28, 2012 | Zanussi FJS1225W Front Load Washer
I have an IDC75 condenser dryer. Everytime i press the start button to start drying my clothes, it will not allow me to start it and immediatley shuts off the electricity in the whole kitchen. PLEASE,...
the culprit seems to be the CONDENSER BOX. This can quickly get blocked up by soggy wet lint/fluff debris from clothes. Some clothes shed more than others, so it is best to check this frequently. What happens is that when the CONDENSER BOX gets partially blocked up, it fails to condense the steamy moist air into water efficiently, and the insides of the drier start to get damp ans steamy. Depending on the amount of moisture, and the make (Some Zanussi and Hotpoint driers may be vulnerable to this), if any vulnerable electrical part get too damp, then there will be a "flash-over" between a live component and neutral or earth (usually a part connected to the casework). This can cause the kitchen circuit breaker to trip. The fix: remove your condenser box, and give it a good spray clean in the garden with your garden hose. Any large lumps of fluff/lint that are stubborn can be pushed out from between the condenser slots with a plastic ruler. Allow to dry. Then , with power removed from the drier, use a good flashlight checking that there has not been any build-up of fluff behind the condenser box area at the rear. You may need to remove the water tank as well to see more clearly. It is worthwhile also checking the little buffer-tank at the back, where there is a level sensor switch for the water tank level. If it is full of gungy water and lint, try to give it a clean out. Give your machine an hour or 2 to dry out internally a bit before attempting to dry any clothes, in case the breaker goes again. If it DOES go again, try leaving it for linger. If it still fails after being left for 24 hours, there may be a more permanent fault, inside the top back of the dryer there should be a wiring diagram(might be on the back panel of dryer) you will need to trace wires and with multimeter try to figure out what is causing the short. Hope this helps Tim
Nov 25, 2010 | Indesit Dryers
Zanussi ZETF180 Freezer Refrigerator not coolling. compressor is working but refigerator is not. The freezer is cold but all the ice melted. Have up'd the thermostat to full clod to see if this helps. Do...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 11, 2010 | Zanussi ZETF180 Top Freezer Refrigerator
Zanussi jetstream 1000 turbodry door remained locked this morning. Emptied machine through filter port and cleaned filter. Door opened ok. Machine will now not start any program although the power light...
the drain pump is jammed .........remove the filter at the bottom left of the machine get down and look in the hole and you will likeley find something in there if not you need a new pump
Feb 26, 2010 | Zanussi FJS1225W Front Load Washer
Zanussi DCE 5655 dish washer
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
Zanussi TC7102W Electric Dryer Logo
470 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
