Sound button not working - Televison & Video
  • Televison & ... Master
  • 17,130 Answers
Does this mean that there is no sound , if so check the speakers after disconnecting power plug. check the power amplifier output IC, voltage from the power supply, if present the IC can be faulty.
However if the sound is present then the touch pads switches can be faulty. remove clean and reset.
Check the contacts, and the signals to the processor.If not replace the switches .
Posted on Dec 31, 2010
Lionel train problems
Make sure the A or D terminal is connected to the center rail. U terminal to the outer rail. First do this without the sound activation button. Horn should sound this way. Once this works correctly, add the sound button in on the center rail lead (A or D) If the sound activation button activates the horn, reverse the connections to the sound activation button.
This should solve your difficulties
Dec 04, 2013 | Crafts & Hobbies
The sound wont work and iv'e tried holding Fn and the sound buttons and it wont work what else can I try
Try using acer recovery to reinstall the application and driver.
start/programs/acer/recovery
Apr 02, 2013 | Acer Aspire 9500 Notebook
My volume buttons on my compaq presario c769us are not working , is there a combination for the volume buttons
From the manual:
http://h10032.www1.hp.com/ctg/Manual/c01114193.pdf
Hotkeys are combinations of the fn key (lower left of keyboard) and one of the function keys:
Mute and restore speaker sound. fn+home
Increase speaker sound. fn+pg up
Decrease speaker sound. fn+pg dn
To use a hotkey command on the computer keyboard, follow either of these steps:
Briefly press the fn key, and then briefly press the second key of the hotkey command.
- or -
Press and hold down the fn key, briefly press the second key of the hotkey command, and then
release both keys at the same time.
Muting speaker sound (fn+home)
Press fn+home to mute speaker sound. Press the hotkey again to restore speaker sound.
Increasing speaker sound (fn+pg up)
Press fn+pg up to increase speaker sound. Hold down the hotkey to increase speaker sound incrementally.
Decreasing speaker sound (fn+pg dn)
Press fn+pg dn to decrease speaker sound. Hold down the hotkey to decrease speaker sound incrementally.
More manuals for this model:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3678775&
Jan 25, 2013 | HP Compaq Presario C769US Notebook
I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
lojr,
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
filestream.ashx?id=435
2. Press the RECEIVER POWER button on the remote.
filestream.ashx?id=436
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
filestream.ashx?id=438
4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
filestream.ashx?id=440(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
filestream.ashx?id=442
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
Jan 13, 2011 | DISH Network IR Remote Control
My lock button as well as my sound buttons won't work
It sounds like you may have accidentally turned them off. To make sure the sounds are on, do the following:
1. Click on "Settings"
2. Select "Sounds"
3. At the bottom you will see "Lock Sounds" and "Keyboard Clicks".
If the sounds are on, I would then recommend preforming what's called a "Soft Reset". To preform this, do the following:
1.Press down the "Home" button and the "Lock" button at the same time.
2.Hold these buttons until you see the apple logo appear.
3.The iPhone may take up to 2 minutes to come back to your "Lock Screen"
This should fix your problem.
Oct 06, 2009 | Apple iPhone Smartphone
Just recieved a lg mu-42pz90v plasma t.v. We got
If your tv came with a remote, make sure sound is not turned to Mute.
Also try to press the DASP button repeatedly to select the appropriate sound setup to "Flat", "Music", "Movie", "Sports" or "User".
You can also do this from the Sound Menu.
Press MENU button and use up and down arrows to select SOUND.
Then press the left [>] button and use up and down button to select desired sound option. Press again left [>] button and up and down buttons to make appropriate adjustments. Press Enter to save.
Make sure cables for audio is also properly plugged to the right port.
Sep 21, 2009 | LG MU-42PZ90V 42 in. Plasma Television
PIONEER DEHP3500 ONLY VOLUME BUTTON WORKS PLAYS CD BUT BUTTONS DONT WORK ON CD EITHER RADIO DOES NOT WORK AT ALL
hi im using pioneer DEH-5750MP pnly sound is working and no other button is working ,cd is working fine but cant acces the radio as no other button is working
Jun 08, 2009 | Car Audio & Video
Dv6120us power button dont work
None of the buttons will work untill the power is turned on and no sound will be heard.
You might want to try charging the battery by connecting the AC adapter to the laptop and plugging it into the wall outlet.
With the AC adapter connected, try powering up the laptop.
I hope this helps.
Good Luck.
Mar 25, 2009 | HP Computers & Internet
Prescario v6000 mute buttons and sound button dont work
you have to install the driver
get you driver driver through hp site
Oct 04, 2008 | HP Compaq Presario V6000T Notebook
Blue buttons (quickplay/sound/dvd controls) won't work
Mine did that as well then after rebooting started working??
Aug 16, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
