Question about Kyocera FS-2000D Laser Printer
Error power off f000 impressora FS-2000D - Kyocera FS-2000D Laser Printer
  • 56 Answers
SOURCE: Kyocera FS-2000D
Hi, Sound like drum unit is out off position.
Switch off printer.Open left side door, remove waste toner bottle and push drum unit(with grej lever on it) in printer to proper position.If grey lever is not in proper position, drum will be not locked.Place waste toner bottle in position.Switch on printer.
Posted on Nov 06, 2007
install new firmware
Posted on Dec 18, 2007
SOURCE: Call Service F000 error
i solve it by turn off the printer and later on after one minute turn on again, it works perfectly.
Posted on Sep 12, 2008
  • 40 Answers
SOURCE: 6000 error on a Kyocera
a fuse it is blown within the FUSER UNIT - replace that fuse or call a technician to do it for you.
Posted on Jan 10, 2009
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
I have a kyocera FS-2000D and an error 6000:0087166 what can I do...???
Error Code 6000 is fuser code, you need to replace the fuser unit, make sure there is no paper stucking there first!
Nov 10, 2011 | Kyocera FS-2000D Laser Printer
Kyocera FS-2000D This printer comes up with error code 6120-0044336 at power on Is this a fuser error?
Yes it is a fuser error.
6120 Abnormally high fuser thermistor S temperature
*35/37 and 45/47 ppm printers (EUR/USA model) only
The temperature of the fuser thermistor S detects 250°C/482°F or more continuously for 3 s.
Shorted fuser thermistor S.
1. Measure the resistance. If it is 0 ω, replace the fuser thermistor S.
2. Defective engine PWB.
Replace the engine PWB
Mar 08, 2011 | Kyocera FS-2000D Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
Apr 14, 2009 | Kyocera FS-2000D Laser Printer
I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Mar 21, 2009 | Kyocera FS-2000D Laser Printer
Kyocera FS 2000d meldet " Error.Power Off F050:0000000"
if you installed firmware do it again with different media... media corrupted..
otherwise rom on main board is bad...
Feb 24, 2009 | Kyocera FS-2000D Laser Printer
Call service 7410:0100539 on a Kyocera fs2000d
I have heard that 7410 is a standard code meaning the drum is out of position. Seat the drum correctly and away you go.
David
www.copycare.net
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
Kyocera FS-2000D Laser Printer Logo
470 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
