Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
FISCHER AND PAYKEL WASHING MACHINE IW811 WONT PUMP WATER OUT COMES UP WITH ERROR NUMBER AND TO REPORT TO SERVICEMAN
  • 1294 Answers
SOURCE: Fisher and Paykel - SmartFisher and Paykel - SmartDrive (9) Excellence 7.5 - Pump Blockage
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
Spiz
SOURCE: Our Fisher and Paykel Pride
Sounds like your pump is blocked. **UNPLUG the machine**. lift or drag the machine to a spot where you can let the water dump out. The water comes out fast and makes a big mess. Tilt the machine back. On the front-right underside of the machine you will see the pump with the fan hanging down. Unplug the white plug and the earth cable from the back of the pump. You might notice that there is a white plastic clip that you can move to the side. Hold the clip out and twist the pump clockwise. At this point the pump will drop out and water will go everywhere. Try and take the pump out kinda fast so that the coil does not get too wet while the water is dropping out. you might find a blockage (coil, hair clip, underwire etc) sticking out from where the pump impeller sits. Pull out your blockage and check that the pump spins freely when you spin it by hand. If it does not spin freely you need a new pump.
Now, after you unblock your pump, you can put it back together the same way you took it off. Make sure the white plug is not wet before plugging it into the pump and make sure the pump coil is dry too! use a blowdryer to dry for a minute if unsure. When twisting the pump back in, the wires should be at the back of the machine and the earth cable is kinda close to the rotor (motor). Make sure the pump is sitting flat so the seal works too. That clip should click lock back into place to hold the pump from turning. The washer will not spin until all the water is out in case you are wondering. Hope this helps!
Posted on Aug 02, 2008
  • 27 Answers
SOURCE: Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Posted on Sep 23, 2008
maxrepair1
  • 3 Answers
SOURCE: Fisher & Paykel wahsing machine GWL10 stuck in rinse cycle.
no power from the control board to the diverter.replace control board.it is about $150.00 for the part
Posted on Jan 25, 2009
  • 106 Answers
SOURCE: cannot access pump in fisher & paykel washing machine
There has to be some access somewhere, behind?. Find it out, the problem is with your pump, unplug washer from the electric mains. Drain out your water by lowering the exit hose into bucket or ground drain, dismantle your pump to see what is clogging it. Before that see that the connections to the pump are tight; pull out and refit, it might sort out the problem. Or you have to change the pump. You can do all these yourself. Only note careful as to what came out how & how to refit.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
Posted on Mar 15, 2009
I have a Fisher and Paykel IW811 Intuitive Eco washing machine on which I have recently replaced the pump motor and motor control board. I have reset the size for 650mm.
Switch power off at wall & unplug machine for a couple of minutes. Plug it back in and power on. See if it resets it, If not then you may have a faulty main board or it has been damaged somehow during fitting.
Jan 09, 2017 | Fisher and Paykel Washing Machines
Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Aug 06, 2012 | Fisher and Paykel Washing Machines
F & p iw811 overfills
The problem is going to be your pressure switch but sadly that's part of the main control board as well
May 29, 2012 | Fisher and Paykel Washing Machines
Fisher and paykell Iw811 overfills on wash cycle
The pressure sensor is going bad and soon you will get fault code 66.
May 27, 2012 | Fisher and Paykel Washing Machines
I have a Fischer and Paykel washing machine that is leaking from underneath and is shutting down automatically
Hi just read your posting.Now, I need to know the model number of the machine which is located on a sticker on the back of the machine top left.Please look under the machine to the front right and you should see a fan,This is your pump.Shine a torch at it to see if there is any corrosion on it.Also have a look for any evidence of water on the pump or surroundings.Depending on which model of machine you have if the water is making the pump faulty it will turn the machine turn off automatically.Please reply with the model number and what you find under the machine.Looking forward to your reply.
Oct 10, 2010 | Fisher and Paykel Washing Machines
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
When the washer is pumping water in it makes a noise like the pump is starving for water. I have checked water flow through the lines and the inlet filters ar not stoped up.
The only thing I've ever had to replace on that model washer is the pump, and they go out all the time. You have to order it from fischer and pakel directly, and it is extremely easy to replace (can do it with no tools at all) Remove the wires from the pump. Ther is a plastic tab that releases it so you can turn it. Turn it 1/4 turn and it will come out. To get a pump call 888-936-7872 (fischer and pakel customer care)
Nov 26, 2009 | Fisher and Paykel GWL11 Top Load Washer
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
56 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
