Question about Nokia Classic 2700 Cell Phone
Call barring pass word is blocked - Nokia Classic 2700 Cell Phone
  • Nokia Master
  • 554 Answers
My Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Posted on Dec 31, 2010
I need to know how to take the fuse box under the hood of my 2005 Chevy Impala so I can put a new one in.
Underhood Electrical Center or Junction Block Replacement
Removal Procedure
  1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
  2. Click to Enlarge
  3. Disconnect the positive battery cables from the underhood fuse block terminals.
  4. Remove the tape from the wiring harness at the base of the underhood fuse block base.
  5. Click to Enlarge
  6. Release the underhood fuse block(s) clip retainers using a small flat-bladed tool.
  7. Click to Enlarge
  8. Remove the fuse block(s) and wiring harness lifting up from the base and reposition from the base.
  9. Click to Enlarge
  10. Remove the nuts from the underhood fuse block base.
  11. Remove the underhood fuse block base from the shock tower.
  12. Click to Enlarge
  13. Remove the underhood fuse block lower front terminal positive assurance retainers using a small flat-bladed tool.
  14. Click to Enlarge
  15. Remove the plastic shields from the battery cable and buss bar terminals, using a small flat-bladed tool to release the clip retainer.
  16. Click to Enlarge
  17. Remove the bolts from the buss bar jumper bar.
  18. Click to Enlarge
  19. Remove the buss bar jumper bar from the fuse block(s).
  20. Click to Enlarge
  21. Remove the fuses from the fuse block(s) to access the buss bar terminal release tabs.
  22. Click to Enlarge
  23. Remove the buss bar(s) from the fuse block(s) using a terminal releasing tool, and pulling down and out on the buss bar.
  24. Click to Enlarge
  25. Remove the buss bar(s) from the fuse block(s).
  26. Click to Enlarge
  27. Release the clip retainers from the underhood fuse block(s) battery cable and buss bar terminals using a small flat-bladed tool.
  28. Click to Enlarge
  29. Remove the underhood fuse block(s) battery cable and buss bar terminals from the fuse block by pulling down.
  30. Remove the fuse block and lamp wiring harness from the vehicle, if required.
I copied the info from my database, sorry, it is read only, The way I copied it, read only, no pictures.
Jan 28, 2018 | Chevrolet Impala Cars & Trucks
July bar exam results
Hi
if the timetable is the same as last year then it should be in October/November, please see extract below.
OCTOBER 31, 2013
Results from the July Texas bar exam are online
Men and women who sat for the Texas bar exam in July are enjoying a special treat this Halloween. The Texas Board of Law Examiners (TBLE) in Austin administers the exam and today posted the names of those who passed the July exam on its site. The agency also provides the pass rate data for each of the nine American Bar Association- accredited law schools in Texas.
Graduates of Baylor University School of Law in Waco take first place among the Texas schools with the highest percent passing rate: 97.52 percent or 118 of 121 of its graduates who took the test for the first time in July, according to the TBLE.
The overall passage rate of Texas grads is 88.74 percent, or 1,561 of 1,759 first-time test-takers. The overall passage rate of Texas law school grads is slightly higher than the 86.49 percent, or 1,524 of 1,762 Texas law school first-time test-takers who passed the exam in July of 2012.
Congratulations to all!
-- Jeanne Graham
Aug 13, 2014 | Computers & Internet
How to get pass st math kickbox level 9?
Try the site below.
How do you pass kick box level 9 on st math
You can also check this out.
To pass the Kick Box level four at 50%, you just move one of the blue bars down to the bottom, many squares work, but I did bottom row, second box from the right. Next, put the other blue bar in the second row from the top and the second box from the right in that row and then hit go. For more information, visit http://www.pulsitemeter.com/pass/-pass-level-kickbox-st-math.html.
May 15, 2014 | Computers & Internet
On Samsung jet s8000 Incoming calls display unknown caller message, but call log shows ID
Check your Sim in another phone to confirm , if there is no CLIP then the service provider has barred you and must get in touch. Also is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Apr 26, 2011 | Samsung Jet S8000 Cell Phone
My sumsung tocco ask for a call barring pass word i have no dial out tone please help whats the 4 digit pass its not 0000
Hi steven,
Normally the default code is as you stated "0000"
You would normally get the code from your network provider.
You can try doing it this way instead though:
The [SEND] button is your call button, green phone symbol.
So for example to cancel call barring you should type #330#0000# [SEND]
To Activate: * 330 * BARRING CODE # [SEND]
To Cancel: # 330 * BARRING CODE # [SEND]
To Check: * # 330 # [SEND]
May 14, 2010 | Samsung SGH-U600 Cellular Phone
I want to access facebook but i work for the new york city department of education and they block the website. how can i bypass the block and log on anyway?
There are few ways to bypass the block and log to the facebook.
Here's one of the way to by pass facbook account.
www.proxify.com and then type in facebook in the page address bar.
it should bypass any firewall.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 29, 2010 | Facebook Social Network
Hi My mobile call barring password blocked.How can I unblock it
Hi My mobile call barring password blocked.How can I unblock it Nokia 6110
Jan 19, 2010 | Nokia 6600
Using a Clarke DU-8R drum sander, I am getting grooves in the floor from one pass to the next, running parallel to the sanding direction. I am sanding right to left as it says. Is there an adjustment to...
If the drum has the bar clamp with the 3 screws make sure the bar is set so the screws are flush when tightened down. If you reverse the bar clamp the screws will stick up a fraction and cause this grooving in your floor.
Mar 02, 2009 | Sander Industrial Original Clarke Floor...
Nokia Classic 2700 Cell Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
