Original games should work unless you are trying to play a game from a different region, for example playing a PAL game on a NTSC console, check on pro evolution soccer to see what it states then check your wii sports and see what region its from make sure they are both the same. Otherwise the pro evolution soccer could be counterfeit.
Region codes are so the console can only pay discs in the same area. For the US the region code is NTSC, Japan is NTSC-J and for UK it is PAL. Be sure to check your disc label to make sure you are trying to play a game with the matching region for your console.
No, the only way is to buy a PS3 from the region you are needing. However, if you own the DVD you can make a copy of the dvd using your computer and the program DVDFAB that will play on your PS3 because DVDFAB will remove the region lock. Hope this helps, let me know if you have further questions.
Region codes is a built-in feature of the DVD system designed to
control where discs are viewed and distributed. All DVD hardware and
software is coded using one of six numbers ( DVDs Regions 0 , 7 and 8
are special cases - see below ). The U.S. and Canada use Region 1.
Region 2 discs are used in the U.K. , Europe and Japan . While
Australia and the Caribbean use Region 4. These codes determine where
the discs can be played.
Your console must match the discs region code. This is not the case so you wont be able to play with this game.
go to the settings menu and if you dont see region right away go to system settings. It will either say region or locale, depending on if you have the new xbox experience or not. if you never had xbox live on it and you bought it new you have the old version.
U need to decrypt your Blu-ray disc. Try this tool(http://www.pavtube.com/blu-ray-ripper/) which can decrypt and rip the m2ts files off from disc. Then u can play the m2ts files on your player. And there is no quality loss during conversion.
