Question about Philips 107E61 17" CRT Monitor
Control menu is locked - Philips 107E61 17" CRT Monitor
Turning off parental controls on Toshiba tv lcd 42hl800A
Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu. Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area
Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
Jan 05, 2017 | Toshiba Televison & Video
My remote is brokend and as soon as i press menu on the tv you will see a lock
sounds like parental controls are engaged, which locks out direct menu control, requiring a 'pin' entered from the remote to grant access. Get a new remote.
Jun 26, 2014 | Hitachi C21-FL21F 21" TV
I cant unlock it
When you enable the Control Panel Lock function, you can lock all of the projector's buttons, or all of the buttons except the Ppower button. The remote control can still be used to operate the projector.
1. Press the Menu button, highlight the Settings menu, and press Enter.
2. Select Control Panel Lock and press the Enter button.
3. To disable the Control Panel Lock function, select Off in the Control Panel Lock menu.
4. Select Yes and press Enter to confirm the setting.
5. Press the Menu button to exit.
*- Or press and hold the Enter button on the projector's control panel for seven seconds. A message is displayed and the lock is released.
If you need a manual for your unit, goto here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=140128&prodoid=63085205
and click "Users Giude".
Jun 19, 2012 | Epson Powerlite S7 3lcd Video Projector,...
Sharp Aquos RC Control Lock and Operation Lock Out
When all else fails read the owners manual page 35:
"• To unlock the buttons on the remote control by using the
touch sensor panel of the main unit (see page 25):
1 Press MENU to display the MENU screen, and then
press VOLl/k to select "System Options".
2 Press CHs/r to select "Operation Lock Out", and
then press INPUT.
3 Press CHs/r to select "Off", and then press INPUT.
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
Apr 05, 2012 | Televison & Video
The remote and control panel are locked on my 52" LED LCD tv.
Hello
To unlock the remote control function do the following.
On the front pane touch control pad
press VOL[--/+] to select "System Options".
2 Press CH [UP/DOWN] to select "Operation Lock Out", and
then press INPUT.
3 Press CH UP/DOWN] to select "Off", and then press INPUT
Out".
OK.
Feb 16, 2011 | Sharp LC52LE810UN 52 in LCD TV
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
How to get rid of osd lock which appears frequently on screen?
Hold the MENU button for ten seconds to unlock or lock the OSD.
This information is from your manual for the L194WT:
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Please rate me if this solution works for you
Thanks......Have a great time
Jul 08, 2010 | ViewSonic Computers & Internet
Monitor Controls Locked
To unlock your monitor, Press and hold the Menu button for 5 - 10 sec. and the OSD menu should be released.
Apr 30, 2009 | SAMTRON 77V 17" CRT Monitor
How to unlock the control lock in my monitor?
hold menu button for 10 secs for 753df
Dec 30, 2007 | Computers & Internet
Philips 109s20 crt monitor
Here's the link for the product support page; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=109S20&scy=us&slg=AEN&grp=PC_PRODUCTS_GR&cat=CRT_MONITORS_CA&sct=CRT_MONITORS_GT19_SU Click "User Manuals" on the left. or here is a direct link; http://www.p4c.philips.com/files/1/109s20/109s20_dfu_eng.pdf Check page 28: "The Main Menu displays OSD MAIN MENU LOCKED . Pressing the front control panels hasno effect. How can I unlock this function? Press and hold the OSD menu key for about 10 seconds until picture displays "OSD MAIN MENU UNLOCKED"" Hope this helps :)
Sep 03, 2007 | Philips Brilliance 109S Monitor
Philips 107E61 17" CRT Monitor Logo
22 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
